First post, by Great Hierophant
Suppose you want to get a Sound Blaster for your old PC. Naturally, to ensure the greatest compatibility you will want to go with Creative Labs products. In my opinion, any Sound Blaster after the AWE32, in 4000+ series, Vibra, or PCI is crap. (Even the AWE32 is hardly worth the bother.) I wouldn't trust any OEM or PnP models either. So, you need to get one or more of the following:
Sound Blaster 1.0-2.1
Sound Blaster Pro 1.0
Sound Blaster Pro 2.0
Sound Blaster 16
Sound Blaster AWE32
Even among these humble cards, there are often many variations, which are displayed by model number. Can anyone direct me to a list that focuses on the earlier, good Sound Blaster numbers that delineate the features of each board. If not, someone should create such a list.
The list should start at the CL-1300, the Game Blaster, and proceed to the CL-3980, the AWE32 PnP.
Reply 1 of 5, by HunterZ
I've got an AWE64 Gold but have never really used it. My understanding is that it's similar to the AWE32 except that you can't put standard RAM sticks in it to increase its capacity.
Reply 2 of 5, by eL_PuSHeR
Some people say AWE32 worked great under ms-dos while AWE64 didn't.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 5, by Reckless
I had a SB 16 (a few in fact!) then AWE 64 then SB Live Value and now SB Audigy 2ZS. Creative do a good sales job 😉
I used my AWE64 in DOS and it worked great! Results can very greatly by the revision of card and the drivers used. Some later DOS cards required drivers just to initialise the card whereas earlier ones didn't. Here's a good starter for a model list:
CT1320 - SB 1.0/1.5
CT1330 - SB PRO 1
CT1350 - SB 2.0
CT1600 - SB PRO 2
CT1680 - SB PRO 2 OEM
CT1690 - SB PRO 2 OEM
CT1730 - SB 16
CT 1740 - SB 16 CSP
CT 1750 - SB 16 MCD CSP
CT 1759 - SB 16 MCD
CT 1770 - SB 16 SCSI-2
CT 1779 - SB 16 SCSI-2
CT1780 - SB 16 OEM
CT1790 - SB 16 OEM
CT2230 - SB 16 MCD CSP
CT2230C - SB 16 CSP
CT2230S - SB 16 SONY
CT2239 - SB 16 MCD
CT2239S - SB 16 SONY
CT2239C - SB 16
CT2740 - SB 16 CSP
CT2749 - SB 16
CT2750 - SB EASY 16
CT2770 - SB 16 VALUE
CT2260 - SB 16 MCD OEM
CT2290 - SB 16 PRO CSP
CT2291 - SB 16 VALUE IDE
CT2299 - SB 16 PRO
CT2800 - SB 16 VALUE OEM
CT2810 - SB 16 VALUE OEM
CT2840 - SB 16 VALUE OEM
CT2860 - SB 16 VALUE OEM
CT2890 - SB 16 VALUE PNP OEM
CT2830 - SB 16 IDE CSP
CT2839 - SB 16 IDE
CT2910 - SB 16 PRO
CT2911 - SB 16 PRO VALUE
CT2919 - SB 16 PRO CSP
CT2929 - SB 16 VALUE PNP
CT2940 - SB 16 VALUE PNP OEM
CT2959 - SB 16 VALUE PNP
CT2960 - SB 16 VALUE PNP OEM
CT2961 - SB 16 BASIC PNP
CT2970 - SB 16 VALUE PNP OEM
CT2980 - SB 16 VALUE PNP
CT4171 - SB 16 WAVEFFECTS
CT4181 - SB 16 VALUE PNP
CT4380 - SB AWE64
CT4381 - SB AWE64
CT4390 - SB AWE64 GOLD
CT4500 - SB AWE64 VALUE
CT4501 - SB AWE64 VALUE
CT4520 - SB AWE64 VALUE
CT4620 - SB LIVE
CT4660 - SB LIVE
CT4670 - SB LIVE
CT5320 - SB MCV
CT5330 - SB PRO MCV
Reply 5 of 5, by robertmo
i also attach documentation no longer available on creative labs page
