First post, by lowenz
Dege, can you check 2.54 in Raven Shield 1.60 ?
I got a crash in fullscreen mode loading a mission level.
No problem in windowed mode (set from the game itselft via config file), except you can't move the window.
Is there any way to force (maybe in future versions of DGV) the starting X and Y of the active main window?
Reply 1 of 3, by Dege
lowenz wrote:
Dege, can you check 2.54 in Raven Shield 1.60 ? I got a crash in fullscreen mode loading a mission level. […]
Ok, of course, I just need a free time slot for that. 😀
For hacking window position and other titbits, I should implement a text format config file, I think.
