First post, by GL1zdA
- Oldbie
I'm trying to launch Windows/386 2.1 using DosBOX (0.74). The setup goes smooth, but then I get (when trying to launch Windows):
"Error: High Memory Area in use"
I disabled XMS and EMS, but now I get:
"Unsupported DOS version"
I tried 'set ver 4 01' etc but it doesn't work (should work)
I've got setver from 6.22 and dynaload from IBM PC DOS, but trying to load setver using dynaload doesn't work - 'Driver did not stay resident'.
Any hint how to get this running? (Windows 2.0 is supported on the DosBOX compatibility list, so I though 2.1 might also work).
