diff and patch for win32
First post, by joe_pool_is
I have some patches I want to try on my version of DosBox, but they are diff or patch files. I am having a terrible time trying to do all of this manually using Notepad. I did a Google on "diff patch win32." That pulled up half the pages on the Internet, and the relivant links were no longer active.
Are there utilities somewhere?
Wanted: Gasoline and matches.
Reply 2 of 29, by HunterZ
Yep, looks like those are Win32 ports of the GNU diff/patch tools that all those *nix people used to make the diff/patch files in the first place. So, those should work well.
Reply 3 of 29, by joe_pool_is
I installed both diff and patch from the sourceforge download page, then updated my path so that my command line terminal (eh... DOS window?) would know where the new diff.exe and patch.exe files were.
Expecting fabulous results, I typed in "coreswitch.patch" at the prompt. Windows brought up a dialog box asking me to select which program I would like to use to handle files of type .patch. I browsed to the proper directory and selected the patch.exe file. (Patch knows to call diff.exe, I guess?)
Now my terminal appears to be hung:
C:\DOSBox>coreswitch.patch
TMPPATNAME: C:\DOCUME~1\jpool\LOCALS~1\Temp/ppwR1K1R
Okay, now I'm lost! Did I do something incorrect?
Reply 5 of 29, by joe_pool_is
This is getting frusterating, but how do I "apply" a .diff file? Specifically, I am wanting to apply the "serialport_patch2.diff" file. diff is for getting the difference between two files or folders, so I don't see how this file is used. I apologize for my ignorance.
Reply 6 of 29, by HunterZ
I think .diff and .patch files are the same thing. Diff creates them and patch applies them.
Reply 7 of 29, by Qbix
Rank DOSBox Author
DOSBox Author
patch -p0 < serialport_patch.diff
the proper extestion for a patch is confusingly diff (I think ( as patch applies a diff))
Water flows down the stream
Reply 8 of 29, by HunterZ
Either way would make sense, but not both 😀
Reply 9 of 29, by MiniMax
Rank Moderator
Moderator
... and the patch program do not care about the extension anyway (as any well-behaved Unix program should).
joe, just a few pointers about that -p0 stuff. Unlike in real life, not all patches are created equal. Some includes extranous path-info (/path/to/some/file-to-patch), some don't. The -p option is used to strip some of that path-info away, allowing patch to find the right file. I think the 0 says "strip the initial /". Depending on the situation, you might have to use -p1, -p2, etc.
Oh - as an alternative to < serialport_patch.diff, you can also use the -i (input option): patch -p0 -i serialport_patch.diff
_________________
Reply 10 of 29, by joe_pool_is
I really appreciate all the help. Now I seem to be having another problem: When I enter the patch command, I get errors.
C:\>patch -p0 < c:\dosbox\serialport_patch2.diff
can't find file to patch at input line 6
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|Index: include/bios.h
|RCS file: /cvsroot/dosbox/dosbox/dosbox/include/bios.h,v
|retrieving revision 1.9
|diff -r1.9 bios.h
File to patch: EOF
Skip this patch? [y] ^C
C:\
My directory structure is as follows:
  • * Folder DOSBox is on the C: drive;
    * patch files are located within C:\DOSBox;
    * subfolder "dosbox" is located within C:\DOSBox and contains the 0.63 version from SourceForge.
Where is patch expecting my files to be? Do I need to adjust the -pxxx parameter as MiniMax suggested? If so, what magical value of xxx would/should I use?
Maybe a pic will help:
Reply 11 of 29, by Qbix
Rank DOSBox Author
DOSBox Author
run the patch from c:\dosbox\
Reply 12 of 29, by joe_pool_is
Uh oh! I'm beginning to see new problems.
Previously, I applied the realtime clock patch, and now I am trying to apply the serial port patch. Unfortunately, the realtime clock patch seems to have modified some of the same code that the serial port patch needs to modify.
The serial port patch says to do this:
238,240c848,851
< for (i=base;i<=(base+8);i++) {
< IO_RegisterWriteHandler(i+8,WriteSerial,IO_MB);
< IO_RegisterReadHandler(i+8,ReadSerial,IO_MB);
> IO_RegisterWriteHandler(i,WriteSerial,IO_MB);
> IO_RegisterReadHandler(i,ReadSerial,IO_MB);
whereas that section of serialport.cpp reads as:
for (i=0;i<=8;i++) {
WriteHandler[i].Install(base+i+8,WriteSerial,IO_MB);
ReadHandler[i].Install(base+i+8,ReadSerial,IO_MB);
Does anyone have a suggestion that would help me modify this? I feel only mildly wrong by modifying the for loop to include the base number, but I am at a loss of what to do about the two different types of functions being called. Should I call them both, or is one set better than another? (Should this be the topic of a new thread? I hate seeing my name on so many threads on here.)
Reply 13 of 29, by Qbix
Rank DOSBox Author
DOSBox Author
you seem to using old patches.
are you certain you are using the latest version of the serial port patch ?
Reply 14 of 29, by MiniMax
Rank Moderator
Moderator
Aren't you short of a DOSBox there, Qbix?
The magic word in that patch is Index: include/bios.h. With C:\DOSBox\dosbox as your working directory, the path should match.
For pure entertainment value, you could try going one level down to C:\DOSBox\dosbox\include, and try a -p1 to have patch ignore the include part.
_________________
Reply 16 of 29, by joe_pool_is
Uh... I thought I was. I downloaded serialport_patch2.diff from SourceForge, as it had a newer date on it than serialport_patch.diff did. Is there something else I should have used? (Drats!)
Reply 17 of 29, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
The latest version is in
DirectSerial patch
Since I used the february CVS as my base, a diff file would cause the same problem, and I didn't make one. I put all files I modified in a folder.
Reply 18 of 29, by joe_pool_is
h-a-l-9000,
I downloaded dosboxserial2.zip from your thread.
When I tried to compile, I got that a few things were missing.
  • On bios.h, I had to add BIOS_COM3_TIMEOUT and BIOS_COM4_TIMEOUT;
  • I added the contents of the dosbox\src\hardware\serialport folder to my project
There must be something else missing that I can't find, because I am currently getting these errors when compiling (ignore the warnings):
------ Build started: Project: dosbox, Configuration: Release Win32 ------
Compiling...
sdlmain.cpp
\DOSBox\dosbox_hal\src\gui\sdlmain.cpp(1154) : warning C4297: 'SDL_main' : function assumed not to throw an exception but does
__declspec(nothrow) or throw() was specified on the function
directserial.cpp
\DOSBox\dosbox_hal\src\hardware\serialport\directserial.cpp(37) : fatal error C1083: Cannot open include file: 'qextserialport.h': No such file or directory
serialdummy.cpp
\DOSBox\dosbox_hal\src\hardware\serialport\serialdummy.cpp(43) : error C2661: 'CSerial::CSerial' : no overloaded function takes 6 arguments
\DOSBox\dosbox_hal\src\hardware\serialport\serialdummy.cpp(46) : error C2039: 'Init_Registers' : is not a member of 'CSerial'
../include\serialport.h(103) : see declaration of 'CSerial'
\DOSBox\dosbox_hal\src\hardware\serialport\serialdummy.cpp(46) : error C3861: 'Init_Registers': identifier not found, even with argument-dependent lookup
\DOSBox\dosbox_hal\src\hardware\serialport\serialdummy.cpp(74) : error C3861: 'changeMSR': identifier not found, even with argument-dependent lookup
\DOSBox\dosbox_hal\src\hardware\serialport\serialdummy.cpp(81) : error C3861: 'ByteTransmitted': identifier not found, even with argument-dependent lookup
Generating Code...
Build Time 0:06
Build log was saved at "file://c:\DOSBox\dosbox_hal\visualc_net\Release\BuildLog.htm"
dosbox - 6 error(s), 2 warning(s)
---------------------- Done ----------------------
Build: 0 succeeded, 1 failed, 0 skipped
Is there a file of definitions that I am missing?
Reply 19 of 29, by joe_pool_is
h-a-l-9000,
The missing file is: 'qextserialport.h'
Could you send it? Does it also go in the same hardware\serialport folder?
