First post, by riantboy
HI ALL,i am using dosbox on my zaurus.It is a pda with linux os.And its os is PDAXROM,a rom based on X11.
But the emu speed is not fast enough.i used the config file to change the cycles and frameskip.i tried cycles=500,1000,2000,2500(default),5000.I found 1000 is better.But I know this is not the best:)AND I used frameskip=0,5,10,and so on,of course the bigger,the faster.
so i need your help that whick value of "cycles" is the best on my zaurus(with a intel xscale pxa255 400mhz)?
thanks very much:)
