First post, by keropi
- l33t++
Hiya!
I was searching eBay and found someone using this hardware info program:
any idea where to grab it? PC-Config 7.33 yielded no results for me... 😵
TIA!
Hiya!
TIA!
I can find newer version 9.33:
http://www.holin.com/cindex.html
download PC-Config here: Vetusware.
awesome, thanks for the leads kixs!
Using Wayback Machine it is downloadable from the author's site: https://web.archive.org/web/20080312083515/ht … com/cindex.html
Glad to help 😀
I suppose you don't want anymore the 7.33 version, right? Also keep in mind it was still shareware back then.
I don't thin it's needed anymore konc, 9.33 seems to have the same system reqs and it recognizes more hardware.
Btw, 9.33 comes with a key from the author - maybe it will work in older versions as well?
wrote:http://www.holin.com/cindex.html
Looks like that's the same author who wrote WhichCPU (wcpu)! ^^
Re: How can I ensure I'm running in real-mode dos?
wrote:Btw, 9.33 comes with a key from the author - maybe it will work in older versions as well?
Nah, as expected it doesn't work. According to the FAQ it doesn't work even for the same version:
Q) I'm a registered user, why does the new version not work with my .REG file?
A) You cannot switch a sharewareversion to fullversion with your .REG file. Please see the documentation, where to find updates of the fullversion.
pppffftttt 🤣
