First post, by Staticblast
My GeForce 2 MX200's fan crapped out long ago, and I've since lost both the fan and the screws (stupid of me, yes, but I was a kid who didn't know I'd be into retro hardware).
I know, I know, you can get it and even the MX400 for relatively cheaply on eBay, but I specifically want to fix this one up for sentimental reasons, since it was my first ever 3D card.
Now, I know it's a 40mm fan with a 2-pin connector, but I'm not sure what kind, 5V or 12V. Also, is there more than one 2-pin connector type/size? And, since I know the brand is good quality, do you think the Noctua A-series would be a good option?
4-in-1 build (thanks Phil!): AMD K6-III+ 450 / SOYO 5EMA+ / 128MB SDRAM / 80GB Seagate HDD / Voodoo 3 3000 / Orchid Righteous 3D / Sound Blaster CT2960 / MPU-401 PCMIDI Clone / HxC Floppy Emulator / 15" CRT monitor
Reply 1 of 10, by Tetrium
A pic of the card will help.
The fan was probably 12v. Btw, you probably can mount a fan on your card that's connected to your PSU directly (by molex of by use of a fan adapter).
You could even rig another heatsink on there, but a pic of the card will help. The MX2 probably doesn't need extensive cooling anyway, so I think you could get away with pretty much any cooling solution 😜
My retro rigs (old topic)
Report spammers here!
Reply 2 of 10, by chinny22
A lot of MX200's only had heatsinks, and later ones didn't even have that! Popular opinion is that the fan wasn't really needed. However keeping hardware nice and cool is never a bad thing!
As long as you have decent air flow You can probably get away without a fan on the card itself, if something generic doesn't fit
Reply 3 of 10, by Staticblast
Sorry about that. Here it is:
I'd rather not connect it to the PSU directly (the one I'm using has few enough molex connectors going round as it stands), but I'll keep the sggestion in mind.
Reply 4 of 10, by nforce4max
Measure diagonally across the heatsink then get on eBay for a fan of that size in mm, the fan header is either 5v or 12v but it won't matter as pretty much every fan you can get will run just fine at 5v. Just compare with the old fan as to where the positive and negative pins are then pull the plastic header off leaving the two pins exposed then press the connector of the new fan onto that. Amazing how people these days do not know this yet it was pretty common in the late 90s to mid 2000s to bodge budget hardware this way to keep things going.
Reply 5 of 10, by dexvx
Dumb question, but I have this one TNT2 card where the plastic header literally will not pull off. Is there a trick to get it off? The annoying thing is that there is a capacitor that's in front of the header.
Reply 6 of 10, by deleted_Rc
Seems like a standard vga cooler can't see if it has mounting holes or thermal adhesive was used. I suggest also removing the the heatsink and replacing the thermal pas te. If it's glued just gently heat the heatsink and gently twist it.
Usually a fan with molex is pass through fm design so you won't lose a molex connector. If the card has onboaRd power just cut the cables and connect them through some shrink wraps (I do this alot)
Reply 7 of 10, by nforce4max
The little white plastic portion of the header with a little effort lifts right up off leaving the pins still in place. A very small flat tip screw driver or fine blade will get the job done though I have done it with pliers before.
Reply 9 of 10, by deleted_Rc
dondiego wrote:
That card doesn't need a fan at all.
A voodoo card doesn't need a fan either but cooling it is adviced anyhow. If op wishes to cool his card actively its his choice and has reason to do so 😀
Reply 10 of 10, by Staticblast
I'll look into the molex suggestion a bit more, then. Thanks!
Yeah, the four circles in the corner of the heatsink are screw-holes. I definitely know there was a fan on there before. And besides, nothing wrong with getting a little fancy with a hobby, right? 😀
