Crusaders of the Dark Savant & DosBox
Reply 20 of 40, by HunterZ
Yeah, sounds like it's looking in the wrong directory or for the wrong filename. Make sure you're giving it the DOSBox virtual path and not the real one if they're different.
Reply 21 of 40, by eL_PuSHeR
Wizardry 7: Crusaders of the Dark Savant works fine for me under DOSBox 0.63 - Haven't tried "Wizardry 6: Bane of the Cosmic Forge", though.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 22 of 40, by bknight
I'm not sure what you mean about virtual path.
The command that I used was mount c C:\DSAVANT, it is interesting that you mention this, because I looked in the command window and got errors:
Warning: File creation failed: C:\DSAVANT\DSAVANT\SAVEGAME.DBS
Now I wonder if I neeed to change the file location in the game to just C:?
That worked, thanks for giving me the clue to that. Now just have to tweek the speed a bit as it is slow, I've tried pushing F-12, without success during the game. Does the function key need to be pushed prior to loading the game?
Reply 24 of 40, by bknight
Yes, thanks, that worked, I didn't look carefully at the directions. It speeded up but its still a little slow with the cpu at +/-95%. I'll try increasing the frame skips the next time I get into the game.
Reply 25 of 40, by eL_PuSHeR
I see you have read the readme and are on the right track... 😎
Intel i7 5960X
8 GB DDR4 (2100)
Reply 26 of 40, by bknight
Yes, it always helps to read the instructions, something I do last after everything else doesn't work, too anxious to get into the game.
This is on the BOCF, does anyone have a password list like I have in Crusaders? I can't carry the manuals with me in my travels.
Reply 27 of 40, by eL_PuSHeR
Nope. That would be illegal. You will have to ask elsewhere...
Intel i7 5960X
8 GB DDR4 (2100)
Reply 28 of 40, by HunterZ
The game takes little CPU power if you use the dynamic core. I run at 10000 cycles on my Athlon XP 3200+, but it would probably run just as well on half that.
I recently beat BotCF in DOSBox, but I played the Ultimate Wizardry Archives version which has the copy protection removed. I had a printable password sheet like 10 years ago for use with the original version I had, but I've long since lost it.
I'm now playing Win7:CDS myself in DOSBox (although I might get distracted by Guild Wars) after importing my party from Wiz6:BCF.
Reply 29 of 40, by bknight
Why? The passwords I have for Crusaders was in a text file on the CD, unfortunately the symbols in the Bane don't lend themselves to putting into a text document.
Reply 30 of 40, by HunterZ
What CD?
Reply 31 of 40, by bknight
CODS, I don't know when I got it, but the date on the price sticker looks like 2/99?
But I had the Gold CD also, and it may have been on that one too. Lost that along the way. Now have the Archives, which doesn't have the passwords, isn't that smart, buy 7 games and no password files.
Reply 32 of 40, by HunterZ
The Ultimate Wizardry Archives versions are pre-cracked and only come with one manual covering all the games.
Reply 33 of 40, by bknight
That is the CD that I copied for 6 & 7 and I still get a password question when playing 7. I haven't tried 6. Is the manual in the readme files?
I'm asking becasue I don't have the CD and only copied the 2 games from it to my laptop.
Reply 34 of 40, by HunterZ
You're supposed to hit enter when you get the password prompt.
Reply 35 of 40, by bknight
OK, Thanks I'll try that next Time.
Reply 36 of 40, by bknight
I tried W6, and the game works fine, but I am having the same trouble with saving. I changed the location of the saved game file to C: as I did with W7, but all I get is insert c: to save and I can't get out of that screen, have to shut down DosBox to get out. I tried c:\BANE\ also but the same message comes up. The scenario location is c:\BANE\ and can't be changed, only the saved game location.
The command that I'm using is
mount c c:\BANE\ to get into the game.
Reply 37 of 40, by HunterZ
You should do:
mount c c:\ instead of mounting the BANE directory. I think BANE is very picky about where it thinks it's being run from.
In general you shouldn't mount a game's dir as the root dir anyways, since most people don't install games to their root directory in real life (although I knew a few people that did and thought they were crazy even back then 😉)
Reply 38 of 40, by bknight
Very tricky, I guess. Tried mounting c:\ change directories to \Bane and tried playbane.
No luck when savegame location:
C:
C:\
C:\BANE\
Anything else you could think of to try?
Reply 39 of 40, by HunterZ
The BANE directory and/or files in it (especially savegame.dbs) aren't set to read-only by any chance, are they?
Hmm... Just played around in the game, and it seems that for me it only works correctly if the savegame location box is completely blank. It also took me a minute to figure out that I had to hit the right arrow key to get a typing cursor in the box (I'm using keyboard mode because the version I played back in the day was before they added mouse support, and IMHO it's a much more efficient control method)
