First post, by trepan
I made a program in NASM.
It crashes.
Code :
BITS 16
ORG 0x100
SECTION .text
; Lets do DTA
mov ah,0x1a
mov dx,buf
int 0x21
; Find a COM file
mov ah,0x4f
xor cx,cx
mov dx,fname
int 0x21 ** we crash here
; Did we find it ...
cmp ax,0x0
je end
fname	db	'c:\*.com',0
buf db ' '
DosBOX 0.63 [Core:simple and full] Running FreeBSD/4.10 XFree 4.x ; Sound disabled; RAM : 256MB [system] 4;8;16;32 [Dosbox]
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
yes
you must use 4e first to initilase the dta. (and get the first result)
while this crash has actually been fixed in the cvs. you will not find a file.
if you only use 4f
Water flows down the stream
Reply 2 of 2, by trepan
Stupid me 😊
I made just a typo 😜
