First post, by SaxxonPike
SaxxonPike
Offline
- Member
Okay, FT2 works great under DosBox, provided you've got the settings correct... however, I can't use some of the shortcuts (namely, the CTRL-F3 through F5 ones) because they are currently in use by DosBox. Is there a way to disable these in DosBox?
