IDE Command protocol
First post, by vladstamate
Is there a good place documenting the IDE commands, their parameters and their expected responses?
For example for floppy disk controller I have this: http://www.isdaman.com/alsos/hardware/fdc/floppy.htm. Which is great!
In fact same guy has good documentation for IDE here: http://www.isdaman.com/alsos/hardware/hdc/. However most of it is aimed at more advanced HW (ATA-6 for example).
I've looked at existing emulator implementations (like Unipcemu and PCEM) and I learned a lot but they also seem to mash more things together (ATA, ATAPI, IDE, CDROM).
What I am looking for is: hey if you want to read send LBA address (sector, cylinder, head) and _THIS_ command and then the controller will call _THIS_ IRQ and give you back _THIS_ structure to tell you how your read went.
YouTube channel: https://www.youtube.com/channel/UC7HbC_nq8t1S9l7qGYL0mTA
Collection: http://www.digiloguemuseum.com/index.html
Emulator: https://sites.google.com/site/capex86/
Raytracer: https://sites.google.com/site/opaqueraytracer/
Reply 1 of 6, by vladstamate
Found another good description:
ftp://ftp.seagate.com/acrobat/reference/111-1c.pdf
Reply 2 of 6, by superfury
My emulation is based on two specifications only: ATA-1 for emulated harddisks and ATA/ATAPI-4 for CD-ROM drives(still buggy for some unknown reasons).
Yes, both are combined into a single version, using either ATA-1(HDD only) or ATA/ATAPI-4(CD-ROM only). And even so, only implemented the mandatory commands(and read/write many commands, since XT-IDE strangely seems to assume they exist with autodetection, even though they aren't mandatory).
UniPCemu Git repository
Reply 3 of 6, by vladstamate
Yes that is fine. I will be doing exactly the same thing. However when you learn that is a bit less clear 😀
That makes sense. My aim will initially be the same.
Reply 4 of 6, by Jepael
I would have suggested older ATA specifications and OSDEV articles/examples about ATA storage devices.
Reply 5 of 6, by Jo22
Me, too. Personally, I'd also make sure good WD1003 compatibility is assured.
http://geekscomputer.blogspot.de/2008/07/ata- … mmands-set.html
http://www.vcfed.org/forum/archive/index.php/t-41445.html
Edit: Also have a look at an older release of PCE. If you need more documentation, have a look at archive.org.
Magazines and PC repair/compendium books from the mid-80s do often contain valuable information.
Reply 6 of 6, by vladstamate
Thank you Jepael and Jo22, those are good pointers. I'll see if I can compile a list of resources and put it here for other to use.
