Hi!
I tried to run "Der Clue!" - ftp://download:neo@www2.neo.at/Classics/TheClue/DerClou.zip - with dosbox.
The Problem is that installation crashes with a runtime error.
official install instructions are:
# Unzip the files to any directory. Copy the content of the directories Disk1 and Disk2 to two disks.
# Install The Clue! from disk.
I haven't simulated a Disk-Drive with DoxBox (dont know command 😳 )
I just tried installion form C: to C: and from D: (as CD-Rom) to C: (result crash)
if anyone can help i would be pleased 😉
Stockholm, Sweden, Europe, Earth Interests: Old games & young women
RankModerator
Moderator
Posts
5128
Joined
2004-01-18, 04:15
Location
Hi razz,
I tried to get Der Cluo to work with DOSBox, but no matter what I do, it always complains about an unsuitable memory configuration ("Ungeeignete Speicherkonfiguration!").
RankModerator
Moderator
Posts
5128
Joined
2004-01-18, 04:15
Location
Nice work, wd 😀
Could you tell me exactly what the patch do? I tried to disassemble the code around the patch, but I can not tell what it is doing except that you replace a (memory?) test with a register load(?) and an No-Op:
Original:
1 0000:0001BFC1 8B EC MOV BP,SP 2 0000:0001BFC3 83 EC 04 SUB SP,+04 3 0000:0001BFC6 B8 00 10 MOV AX,1000 4 0000:0001BFC9 8B 56 06 MOV DX,[BP+06] 5 0000:0001BFCC FF 1E 96 35 CALL FAR [3596] 6 7 0000:0001BFD0 85 C0 TEST AX,AX 8 0000:0001BFD2 74 11 JZ (+11) ;0000:0001BFE5 9 10 0000:0001BFD4 +0000C12A 89 5E FE MOV [BP-02],BX 11 0000:0001BFD7 +0000C12D C4 5E 08 LES BX,[BP+08] 12 0000:0001BFDA +0000C130 8B 46 FE MOV AX,[BP-02] 13 0000:0001BFDD +0000C133 26 89 07 MOV ES:[BX],AX 14 0000:0001BFE0 +0000C136 B8 FF FF MOV AX,FFFF 15 0000:0001BFE3 +0000C139 EB 1E JMP (+1E) ;0000:0001C003 16 0000:0001BFE5 +0000C13B 81 E3 FF 00 AND BX,00FF 17 0000:0001BFE9 +0000C13F 89 5E FE MOV [BP-02],BX 18 0000:0001BFEC +0000C142 89 56 FC MOV [BP-04],DX 19 20 0000:0001BFEF +0000C145 C4 5E 0C LES BX,[BP+0C] 21 0000:0001BFF2 +0000C148 8B 46 FC MOV AX,[BP-04] 22 0000:0001BFF5 +0000C14B 26 89 07 MOV ES:[BX],AX 23 0000:0001BFF8 +0000C14E C4 5E 08 LES BX,[BP+08] 24 0000:0001BFFB +0000C151 8B 46 FE MOV AX,[BP-02] 25 0000:0001BFFE +0000C154 26 89 07 MOV ES:[BX],AX 26 0000:0001C001 +0000C157 33 C0 XOR AX,AX 27 0000:0001C003 +0000C159 C9 LEAVE 28 0000:0001C004 +0000C15A CB RETF
RankModerator
Moderator
Posts
5128
Joined
2004-01-18, 04:15
Location
wd wrote:
Didn't play it too long, but starts fine.
wd - 2 more questions.
1) How did you install it? Using the game's installer, or did you manually unpack & copy the files?
2) Which version of DOSBox did you use?
When I tried to run the installer with DOSBox 0.63, I always get an "Runtime error 205 at 0000:0DD7" as it is about the unpack/copy the files to C:\DerClou.
The runtime error in the installer is a bug in localDrive::FindFirst.
As the installer searches x:\lha.exe with all attributes set, dosbox
assumes that they are searching for the volume label. Maybe the
conditions there have to be refined to provide correct results here.
So installing will only work with earlier versions (dosbox 0.61) or
by extracting all the files by hand.
