First post, by bluejeans
I have a point of sale machine here that has a riser slot but the thing that plugs into it is just com ports and 12/24 volt usb, not an actual riser that gives additional pci slots. Will a single pci device plug in ok? The reason I haven't already tried it is because I'm going to have to cut a hole in the case to fit any type of card in, there's a bit of metal that's too high to allow a pcb of a card in.
