First post, by ElBrunzy
- Oldbie
I got a guspnp and every time i run some programs from the source directory it return that message : "can't open message file". For instance, iwinit.exe return it 4 times, play.exe write it every time it play a file. Also it seem to mask information that would be in that so called message file.
It's like I'm missing a message file that contain text the programs should display, or it is broken or cannot find ?
I would like to avoid to reinstall and redo all the config.
