First post, by ProfessorProfessorson
Been a long time since I last posted. Anyway, this is my current XP build build I have been fine tuning over the past few months. Specs as follows:
LGA 771 to 775 modded Xeon XEON E5450 @3ghz
Nexus Real Silent CPU Cooler AXM-8200 adapted for LGA775
Asus P5G41T-M SI
Corsair XMS3 4GB (2 x 2GB) DDR3
Galaxy Geforce GTX 460 768mb
SoundBlaster Live 24-bit
SATA Western Digital VelociRaptor 80GB 10,000RPM & Toshiba 500GB 5400RPM drive
DVD Drive
EVGA 430 watt 80+ psu
6x 80mm fans and 1x 60mm fan
3DMark 2k6 scores about 300 points shy of the 17,000 mark. basically powerful enough to run anything XP era @ 1920x1080.
Reply 1 of 2, by Scraphoarder
Nice build you got there. Who made that case? I have something similar with vertical blue led stripes running along both sides of the front.
Reply 2 of 2, by ProfessorProfessorson
Honestly not sure. It must be from around 2k3-2k4 though because most pc magazines I have from that time frame have advertisements from Cyberpower PC and Ibuypower, and they often used this type of case and similar in their systems they sold.
