First post, by Pabloz
When it comes to old 386 and 486 PC cases i was able to find a lot of those china made cases.
Lots of models with the turbo button and the display.
What i found strange is that some of you got a white case, colgate white, and i found the same models with a yellowish color that is not made by the sunlight because if i check the back of the plastic it has the same almond color, and if i do retrobright it doesnt work because almond was the original color. Also the metal covering the case was also painted in almond color.
So was that normal for the era?
I remember PCs like IBMs that were white, Compaq PCs that also were white.
from what year to what year PC cases were yellow?
