First post, by exofreeze
- Member
Fit Up (available on the authors website here) seems to have some issues, so I thought I'd see if anyone here had had any luck with it. The author suggests using dosbox on their website, which would suggest he had it running without much difficulty.
There are two versions on the website.
The "100kb Dos Version" (v0.72) starts, but does not draw the bottom half of the screen.
The "Dos Version" (v0.90) seems to start fine, but after running a couple of boot checks (detects available memory, mouse, sb16), it just sits at a black screen.
I have tried the vanilla and svn versions of dosbox. I've fiddled around with cycles, core, cputype, and disabling upper/extended memory. I also disabled the sounds to verify the issue wasn't there.
The debug version shows it spending a few seconds doing repeated read/writes before it starts returning "illegal unhandled interrupt called 6 / Illegal/Unhandled opcode 0F0D" repeatedly.
Thanks
