First post, by Kreshna Aryaguna Nurzaman
My newest-build PC has a single half terabytes hard drive. It runs Windows XP Pro SP2 32-bit in AHCI mode using AMD AHCI driver (ahcix86). I have the following partitions:
C:\, primary partition, 32 GB. Filled to 20 GB. Mostly Windows and applications.
E:\, primary partition, 32 GB. For Windows pagefile, Photoshop scratch disk, and such temporary files.
F:\, primary partition, about 400 GB or so. For data and disc images. Mostly empty. Games would be installed here.
I'd like to make image of C:\, and stored in F:\, since F:\ has a lot of empty space. I don't care about cloning. What's important for me is the ability to restore the C:\ image into C:\ partition, overwriting the partition. The reason I need it is for because I'm going to experiment with drivers --among other things, with the said computer. So what I need is something like Windows System Restore, but capable to restore the partition bit-by-bit (beside, Windows System Restore is quite disappointing).
I remember having an old copy of Norton Ghost 14 sans manual --got it from corporate surplus years ago. But does anyone have better ideas? Probably something open source?
Kreshna Aryaguna Nurzaman.
Reply 1 of 16, by Jepael
Any linux install media that also has live mode. Ubuntu/Mint family should even have a graphical disk utility that supports imaging these days. They also come with gparted graphical partitioning utility that helps fiddling with partitions (I've resized partitions so they can be cloned to differently sized drives) and for those that are not afraid of the command line, there is a very powerful tool called dd. Just last week I took an image of a whole 32GB Win7 SSD for backup purposes to a 1TB NTFS partition in the same system with Mint 18.2 USB stick using dd.
So, maybe not the best tool. But a tool I use, and available if you have no other tools than internet connection and a USB stick.
Reply 3 of 16, by VileR
Clonezilla boots off a USB stick (or CD) and lets you do partition-to-image backups, saving them as files on other partitions or drives, which sounds like what you want. I use this to back up my boot partition monthly.
Just pay attention to the instructions, and don't do silly things like selecting your source partition when you're asked for the destination. 😀
Reply 4 of 16, by clueless1
In case this is important to you, Macrium Reflect runs in Windows and can be scheduled to run anytime. You create an emergency boot CD, which can be used to restore your backups in case the system is unbootable. You can selectively restore files as well as restore an entire image. And it works in XP (though it may require SP3, not sure).
I like Clonezilla too, but it is limited to manual runs from outside the OS. If I'm cloning a drive, I use Clonezilla, but if I want a normal backup package, I go with Reflect. I'd say Reflect is a better version of Windows 7's built in Backup and Restore. It does image-based backups, can restore selective files, but one thing it does that Backup and Restore doesn't is manage your backups. You can have it keep x backups and automatically prune the oldest backup. That's what I hate about Backup and Restore -- you have to manually go in and delete old backups, or you'll run out of space.
Reply 5 of 16, by mrau
just dd it, simple, fast, free, open;
also: storing data in the free space of a partition is called creating a file ;p
Reply 6 of 16, by Aideka
+1 to Macrium Reflect from me too. It performs reliably, and is pretty fast taking those backups. I have multiple OS images (XP,7,8.1,10) that I made right after installation of drivers and applications I always install anyway, and I have two backups of my current OS. One from a known good configuration, that I manually update every once in a while, and one automatic backup, that backs up my system once every two days. The bootable disk you can make with it is pretty sweet too, since you can add drivers to it, so it can recognize AHCI and RAID configurations, that otherwise might not work when booted from a removable media.
Reply 7 of 16, by Kreshna Aryaguna Nurzaman
Thanks for the replies, guys.
I guess I'll go with Clonezilla. Macrium sounds interesting, but Clonezilla can do its backup from live CD, can it not? I prefer something that doesn't require installation.
Reply 8 of 16, by clueless1
I wouldn't call Clonezilla a backup solution. It's a disk imager/cloner. But yes, it runs from live CD or live USB.
Reply 9 of 16, by Kreshna Aryaguna Nurzaman
Well, I don't really need sophisticated features like differential backups or scheduled backups anyway. I just need something to restore my C:\ partition bit-by-bit just in case I goof up with drivers. 😁
Reply 10 of 16, by Jepael
That's why I still use dd, even though Clonezilla can be thought as a user interface to it 😀 It will also come with OpenBSD floppy, so no need do download multi-gigabyte Linux USB/DVD images.
In fact most of my new PCs have been imaged by dd (in another machine or same machine) before even booting them for the first time from that drive, so they can be restored to same condition as it was unboxed.
Reply 11 of 16, by clueless1
@Jepael -- would you describe your process? What floppy or CD do you boot to, then what command switches do you use with dd?
Reply 12 of 16, by boxpressed
Can Clonezilla clone a 250GB drive to a 120GB drive if only ~100GB is being used?
I remember trying to do this with Reflect, and it was a little confusing. This was because I had three drives on the 250GB drive, and I needed to cut the empty space from only the main (largest) drive.
Reply 13 of 16, by xjas
^^ Yeah, it can collapse down free space. It might have trouble if the drive is highly fragmented though.
Reply 14 of 16, by clueless1
Best if you defragment the drive first and even temporarly shrink the partition to <120GB (to ensure no stray bits are hiding beyond the new destination size). Then when setting Clonezilla, you have to tell it to NOT check destination size and NOT automatically resize partition tables and such.
Reply 15 of 16, by Kreshna Aryaguna Nurzaman
A note about Clonezilla: when I run Clonezilla with my 2TB external drive connected, Clonezilla correctly recognized my partitions as follows:
C:\ (internal hard disk): /dev/sda1/
E:\ (internal hard disk): /dev/sda2/
F:\ (internal hard disk): /dev/sda3/
W:\ (external hard disk): /dev/sdb/
However, it is not always the case. Once, for some unknown reason, Clonezilla recognized my partitions like this:
W:\ (external hard disk): /dev/sda/
C:\ (internal hard disk): /dev/sdb1/
E:\ (internal hard disk): /dev/sdb2/
F:\ (internal hard disk): /dev/sdb3/
Unfortunately, I make images of C:\ and E:\ under that condition, where they were recognized as /dev/sdb1 and /dev/sdb2. Then I booted Clonezilla again to test whether the images can be restored. Alas, during the 'restore boot', the partitions were again labelled correctly, with C:\ as /dev/sda1/ and E:\ as /dev/sda2/. When I restored, Clonezilla does not give error messages. But then the restore failed. How do I know the restore was failed? Because after backing up (and before restoring), I put a \Test folder in C:\. If the restore was successful, then the C:\Test\ folder should be gone. Still, it was still there after restoration.
Then I tried making backup again, this time without the external hard drive connected, so C:\ is correctly recognized as /dev/sda1/ and so on. Then I tried to restore, and it was successful.
Reply 16 of 16, by gdjacobs
I don't think this has anything to do with the mapping. The device nodes /dev/sdXX are created dynamically and can be assigned differently depending on order of insertion. Something else failed in this case.
