Unknown RAM card
First post, by derSammler
I have this RAM card in my collection for quite a while now. Sadly, I wasn't able to figure out model number or manufacturer, so I also have no idea which driver is needed to get the card working. Anyone here can shed light on it?
Reply 1 of 7, by jaZz_KCS
Those DIP-switches sure are interestingly placed. I sadly have no clue what card this is, yet I am fully intrigued...
Reply 2 of 7, by matze79
The switches are to set starting adress of addon ram.
i found one here:
https://www.ebay-kleinanzeigen.de/s-anzeige/1 … 11104-225-19163
It seems the card can fill up XMS Memory, and also supports EMS
so chances are there that you can set both EMS Memory and XMS Memory with each of the DIP Switches.
So you have both types of Memory.
http://www.ebay.de/itm/16-bit-ISA-RAM-Karte-f … JsAAOSwcgNZIFS7
You may want to try the DIP Switch settings on the Photo.
As the Seller states he tested the Card with 4x256Kb RAM on it.
For XMS no driver is needed, the BIOS should simply count it up.
EDIT:
Are you the Seller of this Card ? (identical pictures)
Reply 3 of 7, by derSammler
Yes, that is my card.
The problem is that I can't get anything than 4x 256 KB as XMS working.
Reply 4 of 7, by matze79
Is there a FCC ID on the Card ?
so you can find out who manufactured it.
Reply 5 of 7, by derSammler
No, there isn't.
Reply 6 of 7, by juglenaut
That belongs in a server.
Reply 7 of 7, by derSammler
No, it doesn't! That's a cheap taiwanese RAM card.
