First post, by mg24
I am using DOSBox to run a 16-bit text-based application on a Dell Latitude E6410 laptop running 64-bit Windows 7.
My application runs OK, but the DOS Window it runs in has most of the usual window-menu options disabled. Specifically, I would like to use the "Edit" option that is available in a normal Command-Prompt window and its sub-menu options like "Mark," "Select all," "Copy," and "Paste." Because this menu is unavailable, I can't select and copy text that the program outputs to the screen; I have to transcribe it manually. (It's not just that the menu is unavailable, I can't do it with the usual keyboard shortcuts either.) Is there an option in the config file that can be set to enable that?
