8 Character limit Fix?
First post, by pekr
Hi there
Is it possible with some soft of hack to use more than 8.3 characters in Dos 6.22?
Thanks
Peter
Reply 1 of 5, by jesolo
No, it's a limitation of the FAT file system.
Reply 2 of 5, by Azarien
A limitation that was successfully overcome in Windows 95.
There's DOSLFN, giving you Windows 95's LFN API for long filenames, but only a limited number of DOS programs supports this API.
Reply 3 of 5, by chinny22
Or just use Dos 7 ripped from a Win9x install.
From memory the only things that NEED dos 6 is Windows 3x which there is a hack for, and DOS disk utilities that don't understand fat32 and corrupt the drive
Reply 4 of 5, by Jo22
And pure 16-Bit systems (PC/XT/AT), too. 😀
Reply 5 of 5, by Azarien
DOS 7 is recommended (and 7.1 even more so) but you still need DOSLFN to enable LFN support outside Windows.
