First post, by appiah4
- l33t++
My initial assumption was that, as it is an SB16 with discrete OPL3 and not a Vibra, and is listed as Type 2 bugged in the Vogons Wiki, that it would be bugged. As such, I was planning on using either a YMF-719 or an ESS688 in its place. However, I've stumbled across information that SB16 models with CT1747 OPL3 chips are not prone to this bug regardless of DSP version. Which one is correct?
