First post, by quazirfan
Hello,
I am trying to write a batch script that loops over all file in the current directory and performs some operation on thatm, and I want to use for command to do the looping.
But DosBox says for is an illegal command. After a quick googling I found out, for is not a supported command in DosBox.
Question is, what are the alternate options for me to loop in a batch file in Dosbox?
Thank you.
Reply 3 of 14, by Wengier
And for your information, recent versions of DOSBox SVN-lfn (like vDosPlus's internal shell) has a built-in FOR command. An example:
for %f in (*.iso *.cue) do set cdlist=%cdlist% %f
vDosPlus by default uses the 4DOS 8.00 shell, so advanced options of the FOR command like /F are natively supported by this shell. For DOSBox you have to call 4DOS externally instead in order to support such options.
Wengier
Reply 4 of 14, by Silanda
Personally, I'd like to see this command implemented in DosBox. Before anybody says, "Dosbox is only for games", here's an example of a game that needs better implementation of batch commands: Super-VGA Harrier. While the game works fine in DosBox, the installer is a batch file, containing For, and does not.
Reply 6 of 14, by collector
Wengier wrote:
Since this command is already implemented in DOSBox SVN-lfn, if only DOSBox developers want to add it to the official build...
I wouldn't expect that. No or next no games require LFN.
The Sierra Help Pages -- New Sierra Game Installers -- Sierra Game Patches -- New Non-Sierra Game Installers
Reply 7 of 14, by Wengier
I was only talking about the FOR command in this version though. Even though this build has built-in LFN support (obviously), the implementation of the FOR command (and many additional features like its mouse copy/paste support) is not dependent on the LFN features...
Wengier
Reply 8 of 14, by Osprey
I didn't realize that. Thanks for the info and the work to include the command.
Reply 9 of 14, by Azarien
But having LFN support in the shell would be very useful to quickly cd between directories on disk.
Having to deal with all those progra~1 is so annoying.
I aggree that LFN API implementation is not needed for games.
Reply 10 of 14, by collector
Everything under a mounted folder should conform to the DOS 8.3 filename convention. If you really need LFN support you should probably be using something other than DOSBox, like vDosPlus.
Reply 11 of 14, by Azarien
"Should"... but why? It surely doesn't have to under Windows 9x.
And more often than not, I'm mounting the whole disk, just out of convenience.
