Reply 20 of 25, by Dominus
- DOSBox Moderator
edited out
edited out
maybe someone can close this. Doesn't sound at all like a legit owner of Autocad 12...
wrote:i have all 12 disks of autocad, how i install it?
tell me please the exact procedure?
i will make disk image???
Your DOSBox machine has a floppy drive?
yes
i might be too late but you can try this:
1. move all the files in a single folder.
include the disk.id of disk1 ( exclude other disk.id files).
2. edit the install.dat file and remove all @enddisk command except for disk12 & also remove all @disklabel command except for disk1.
now the folder including all files is modified to read as disk1 by the install.exe program.
3. mount the folder as a cdrom in D drive in dosbox. ( mount d: "folder path/directory -t cdrom -label "Disk1")
4. run install.exe
I am running Generic CAD on my android using Magic Dosbox app. Similar procedure.
