Burned out
First post, by twiz11
I am burned out, what do you or I do?
Reply 5 of 15, by fitzpatr
I'm sorry to hear that, twiz11. The first step is to acknowledge it, which you have done. Now you must analyze what it is, precisely, that is causing this. Then, take measures to fix it...obviously easier said than done. Take some time for yourself, do something you enjoy. Do you like reading, but haven't had time? Too much time at work? Too much stress in your personal life?
I'm no therapist, but I am pretty easy to talk to. If you think it beneficial, send me a PM.
MT-32 Old, CM-32L, CM-500, SC-55mkII, SC-88Pro, SC-D70, FB-01, MU2000EX
K6-III+/450/GA-5AX/G400 Max/Voodoo2 SLI/CT1750/MPU-401AT/Audigy 2ZS
486 Build
Reply 10 of 15, by Procyon
Take it easy for the time being and try to evaluate the reasons what got you into this predicament and make changes to your life so this won't happen again to you in the future.
With this very limited information this is the best answer I can give.
Reply 11 of 15, by StSam
Jade Falcon wrote:
Obey and conform, watch tv, consume, marry and reproduce, sleep , no thought.
Mandatory shot that I slightly modified with confetti from Roger Waters concert.
Memento e-Sinu filo!
