First post, by ratco
I am running MSDOS 7.10 and Windows 98 GUI from here https://web.archive.org/web/20050306014829/ht … dos71/index.htm
I can multitask DOS apps in windows 3.11 GUI but not in Windows 98 GUI. For example, if I have a DOS mp3 player in one window, as long as I click outside that DOS window it will "freeze", only to keep going when I click on it again. Same thin happens if I minimize the window or use "ALT + TAB".
Was it always impossible for Windows 98 to multitask DOS applications and run them on the background? What can I do to work around it??
Thanks.
Reply 1 of 5, by kixs
Check if you have suspend in the background enabled in settings for DOS PROMPT.
Reply 2 of 5, by ratco
No it's not. I checked that actually before I posted 😀
Thanks. What else could cause it to act like this?
Reply 3 of 5, by mrau
is it really paused? or maybe just slowed or muted? because that might be normal
Reply 4 of 5, by ratco
It really stops.
I installed this to use DOS applications, but if I can get some windows98 applications to run (would have to be small, portable, self contained apps) I would maybe let it go of DOS programs 😜
But I don't understand why win3.11 will multitask DOS and win98 won't
Reply 5 of 5, by mrau
i dont have win98 at hand, but still im not sure extreme slowdown and maybe loss of input/output wasn't normal; maybe someone with windows 98 could test? i believe os2 was better at this (and many other things)
i the end this might be depending on software in use;
