First post, by MrFlibble
- Oldbie
I'm trying to run the Surface Tension demo in v0.74 (stock version that came with my Linux distro) but it crashes upon start with a segmentation fault message. I'm running this with cycles=auto 7800 limit 70% 26800 and everything else pretty much set to default. I've tried using no EMS and different video card settings (vesa_oldvbe and vesa_nolfb specifically) but to no avail. Any fix to this? Or should I try a different DOSBox version?
