First post, by Kahenraz
I have a USB-to-PS/2 adapter for my PS/2 keyboard but it keeps falling out of the dongle. I've also had similar problems of PS/2 connectors falling out of the back of a KVM because of a loose connection.
What can be done about these loose fit connectors?
Reply 1 of 14, by TOBOR
I have had good luck with taking a small stick pin and inserting it into the sockets to squeeze the two sections closer together in order to make a tighter fit. YMMV.
If the truth hurts, tough shit.
Reply 3 of 14, by Kahenraz
That tape looks pretty cool. I didn't want to use duct tape because of the residue. Can anyone speak for gaffer tape being safe for that mess?
Reply 5 of 14, by vvbee
Try heatshrink instead of tape for the dongle.
Reply 6 of 14, by Kahenraz
Ohh. I like this idea. 😀
Reply 7 of 14, by luckybob
*scoffs derisively*
Reply 8 of 14, by gdjacobs
Real PS/2 connectors should be made with knob and tube wiring!
Reply 9 of 14, by .legaCy
I would go with magnets.
Reply 10 of 14, by vvbee
luckybob wrote:
*scoffs derisively*
Too easy? In that case, find a knot that pulls two ends together and go from there.
Reply 11 of 14, by Jade Falcon
Rank BANNED
BANNED
Neat idea, but what happens when you want to unplug it?
Reply 12 of 14, by vvbee
If you want to unplug the keyboard from the machine, you unplug it. If you want to unplug the dongle from the keyboard, which likely isn't very often, you nick the heatshrink where there's slack and peel it off. That's why you don't use adhesive heatshrink by the way.
Reply 13 of 14, by meljor
just make it a bit oval with a plier and it wil stick perfectly.
Reply 14 of 14, by Ozzuneoj
Probably your best bet. Try to fix the connection itself first. If that doesn't work, then find alternatives.
