First post, by och
Thinking of building a Pentium 2 system, but it seems that all modern power supplied lack -5 rail on the 20pin connector (essentially making them 19pin)? I really don't want to resort to using an older used power supply. What are my options?
Reply 1 of 10, by BitWrangler
There is very, very few uses for the -5V, unless you've got a 286 or below or you're very sure you need it for something, then don't worry about it. Unless you've got a nasty board that actually looks at all the voltages and throws a wobbly about the one it will never use.
It is fairly easy to rig a -5V supply off the -12V though.
Reply 2 of 10, by gdjacobs
You can find new Startech ATX 1.3 supplies with appropriate rail allocations for Athlon 3200+ type machines and -5V rails. There should also be some availability of FSP/SPI supplies of the same design era as they were still in production until fairly recently. If your P2 board uses AT, Startech makes those new as well.
Reply 5 of 10, by gdjacobs
och wrote:
So I should be ok running ISA Awe64 gold using a power supply without -5v?
There's a thread for that.
Reply 7 of 10, by BitWrangler
.legaCy wrote:
If i recall correctly modern psu has -12v , modding the power supply atx connector and using one 7905 regulator you can create a weak -5v
-5 is kinda weak anyway, and 7905 is good for an amp, depends how crappy the -12V is, I've seen as bad as 300mA so you won't get much out of that, if it's 1A that's nice because average for each was half an amp.
Reply 8 of 10, by gdjacobs
There are switching regulators to invert the polarity as well. See charge pump and buck-boost configurations.
Reply 9 of 10, by .legaCy
If you look for premade modules is kind of okay and way more efficient than a linear regulator(7905), but for diy its kind of way harder to design a buck-boost converter
Reply 10 of 10, by gdjacobs
Premade modules are definitely the easiest, but most VRM application notes have a baseline design that you can roll with.
