Yes, have the Original driver disk (20 MB). Will upload the Monitor Utility...
The attachment SHM.zip is no longer available
This CD contains
VIA Chipset Functions' Registry Patch for Windows 95/98
VIA PCI IRQ Routing Miniport Driver for Windows 95/98
VIA AGP VxD Driver for Windows 95/98
VIA Bus Master IDE Driver for Windows 95/98/NT4
VIA USB Filter Driver for Windows 98
System Health Monitor Utility for Windows 95/98/NT4
User's Manual
The CD contains an installation tool, "AUTORUN.EXE",
in the root directory. When using Windows 95/98 or
Windows NT 4.0, this installation tool will automatically
run (AUTORUN) once you insert the CD into the CD-ROM drive.
AUTORUN allows you to install the following drivers and
utilities. Click your choice to install.
1. VIA Chipset Functions' Registry Patch
2. VIA PCI IRQ Routing Miniport Driver
3. VIA AGP VxD Driver
4. VIA Bus Master IDE Driver
5. VIA USB Filter Driver
6. System Health Monitor Utility
7. User's Manual
8. Browse this CD
9. Readme
10. EXIT
AUTORUN only supports Windows 95, Windows 98 and
Windows NT 4.0 operating systems. If after
inserting the CD, "AUTORUN" did not automatically
start (which is, the Main Board Utility CD screen
did not appear), please go directly to the root
directory of the CD and double-click "AUTORUN".
Auflistung der Ordnerpfade fr Volume MB003
Volumeseriennummer : 3CD0-0DAD
D:.
³ Autorun.EXE
³ Readme.TXT
³
ÃÄÄÄAGP_VXD
³ DATA.TAG
³ DATA1.CAB
³ LANG.DAT
³ LAYOUT.BIN
³ OS.DAT
³ README.TXT
³ SETUP.EXE
³ SETUP.INI
³ SETUP.INS
³ SETUP.LID
³ _INST32I.EX_
³ _ISDEL.EXE
³ _SETUP.DLL
³ _SYS1.CAB
³ _USER1.CAB
³
ÃÄÄÄIrq
³ DATA.TAG
³ DATA1.CAB
³ LANG.DAT
³ LAYOUT.BIN
³ OS.DAT
³ README.TXT
³ SETUP.EXE
³ SETUP.INI
³ SETUP.INS
³ SETUP.LID
³ _INST32I.EX_
³ _ISDEL.EXE
³ _SETUP.DLL
³ _SYS1.CAB
³ _USER1.CAB
³
ÃÄÄÄMANUAL
³ AR32E30.EXE
³ Fcread32.EXE
³ K6BV3rA[392009111].PDF
³ K6BV3rA[39200911C].WDL
³ P5BV3rB[355B09111].PDF
³ P5BV3rC[355B09121].PDF
³ P5BV3sErA[36411912].PDF
³ P5BV3sErB[36421912].PDF
³ P5BV3sErC[36430911].PDF
³
ÃÄÄÄSHM
³ ³ README.TXT
³ ³
³ ÃÄÄÄWin9X
³ ³ DATA.TAG
³ ³ DATA1.CAB
³ ³ LANGUAGE.DAT
³ ³ LAYOUT.BIN
³ ³ OS.DAT
³ ³ SETUP.EXE
³ ³ SETUP.INI
³ ³ SETUP.INS
³ ³ _INST32I.EX_
³ ³ _ISDEL.EXE
³ ³ _SETUP.DLL
³ ³ _SYS1.CAB
³ ³ _USER1.CAB
³ ³
³ ÀÄÄÄWinnt.40
³ DATA.TAG
³ DATA1.CAB
³ LANGUAGE.DAT
³ LAYOUT.BIN
³ OS.DAT
³ SETUP.EXE
³ SETUP.INI
³ SETUP.INS
³ _INST32I.EX_
³ _ISDEL.EXE
³ _SETUP.DLL
³ _SYS1.CAB
³ _USER1.CAB
³
ÃÄÄÄUSB
³ ³ DATA.TAG
³ ³ DATA1.CAB
³ ³ LANG.DAT
³ ³ LAYOUT.BIN
³ ³ OS.DAT
³ ³ SETUP.EXE
³ ³ SETUP.INI
³ ³ SETUP.INS
³ ³ SETUP.LID
³ ³ _INST32I.EX_
³ ³ _ISDEL.EXE
³ ³ _SETUP.DLL
³ ³ _SYS1.CAB
³ ³ _USER1.CAB
³ ³ readme.txt
³ ³
³ ÀÄÄÄDRIVER
³ VIAUSB.SYS
³
ÃÄÄÄVIAPATCH
³ DATA.TAG
³ DATA1.CAB
³ LANG.DAT
³ LAYOUT.BIN
³ OS.DAT
³ README.TXT
³ SETUP.EXE
³ SETUP.INI
³ SETUP.INS
³ SETUP.LID
³ _INST32I.EX_
³ _ISDEL.EXE
³ _SETUP.DLL
³ _SYS1.CAB
³ _USER1.CAB
³
ÀÄÄÄVIA_IDE
³ DATA.TAG
³ DATA1.CAB
³ LANG.DAT
³ LAYOUT.BIN
³ OS.DAT
³ README.TXT
³ SETUP.EXE
³ SETUP.INI
³ SETUP.INS
³ SETUP.LID
³ _INST32I.EX_
³ _ISDEL.EXE
³ _SETUP.DLL
³ _SYS1.CAB
³ _USER1.CAB
³
ÃÄÄÄWIN9X
³ VIADSK.MPD
³ VIAIDE.INF
³ VIAIDE.VXD
³
ÀÄÄÄWINNT
VIADSK.SYS
VIAIDE.INF
