First post, by Jade Falcon
Rank BANNED
BANNED
Looks like UT99 in windows 3.1 or something.
Reply 1 of 16, by mrau
windows 3.1 mode in windows 4?
Reply 2 of 16, by clueless1
I would think something like that could easily be mocked up by someone who knows how to digitally edit. That seems more likely than someone getting UT99 to run in Win3.1. Although, I did find this:
https://www.youtube.com/watch?v=kPy1XKq0Dog
Reply 3 of 16, by F2bnp
Yep, that's probably UT running under Windows NT 3.51, you can totally do it 😀.
Reply 4 of 16, by Errius
I know it runs in NT 4.0, but full screen only in software mode. OpenGL does not work, and DirectX only works in a window.
Is this too much voodoo?
Reply 6 of 16, by Jade Falcon
Rank BANNED
BANNED
Interesting. Thanks guys
Reply 7 of 16, by Cyberdyne
Windows NT 3.51 is very powerful, i have tinkering with it a lot, if you tweak it enough, it is basically NT 4 with the good old 3.1 interface.
And you can have even some Windows 2000 capabilities.
Windows 3.1x is a limited 16bit system, with some 32bit capabilities(Win32s) and it definetly does not run Unreal Tournament, so it is fake!
Reply 8 of 16, by oeuvre
You can see in FIle Manger it says C:\ - NT (most likely NTFS), proving it is indeed Windows NT 3.x
Reply 9 of 16, by konc
All these people here and none satisfied OP request yet
Reply 11 of 16, by F2bnp
hahahahahahahaha
Reply 13 of 16, by Zup
Cyberdyne wrote:
Windows NT 3.51 is very powerful... it is basically NT 4 with the good old 3.1 interface...
Although I think that it may be NT3.51, keep in mind that Windows 9x have a line in win.ini that allows the user to change the shell (and I remember that it includes progman.exe and fileman.exe like Windows 3.x). It does not affect the UI elements (i.e.: maximixe/minimize icons, windows borders), but it wouldn't be too dificult to make a Windows 95 computer mimic Windows 3.x environment.
I'm selling some stuff!
Reply 14 of 16, by BitWrangler
I'm pretty sure there were 3rd party extensions that did it completely.
Reply 15 of 16, by Jade Falcon
Rank BANNED
BANNED
keropi wrote:
^ finally!
Yes thanks. but can you remove the legs?
Just remember we're counting on you.
Reply 16 of 16, by DracoNihil
Unreal engine was developed in Windows NT 3.51, it makes sense UT99 would run under it.
― Κυνικός Δράκων
