First post, by andreja6
I've recently gotten an ESS Audiodrive 1868F sound card, and it has been functioning beautifully as a SB Pro II clone, with the minor issue of some games not even detecting SB compatibility...
Games such as Titus the fox and Ultima 6 don't play any music from the sound card but the PC Speaker (Ultima 6 always plays sound through that speaker).
However games like The Incredible Machine with known problems detecting sound blasters, detects and works fine with the Audiodrive.
I don't plan on replacing it, because when it works (which is 99.9% of the time), it sounds perfect. I had a Sound Blaster Live! with SB emulation, and that was so horrible it put me off creative sound cards that have anything to do with emulation (even SB16's that don't specify a true OPL3 chip)
Reply 1 of 10, by BitWrangler
Played Titus on a few machines, though not recently, and TBH I can't remember it using anything other than the speaker on any of them... or having a setup to select sound card.
Reply 2 of 10, by andreja6
Apparently it has a dreaded Auto detect which which many couldn't get working. Shame
Reply 3 of 10, by badmojo
I could be wrong but I think some auto detection routines are impact by the speed of the machine? Those are some pretty old games - what are the rest of your specs?
Reply 4 of 10, by andreja6
I would not be surprised at all, It's a Pentium II 400Mhz with a VooDoo3, 640MB PC100 RAM and an Intel BX440 Chip-set, And sure enough when I ran it using a slowdown utility, Sound Blaster sound!
However can't say the same for Ultima 6...
Is there any other work-around other than using a slowdown utility? I've been using them for Lotus III, and they are relatively inaccurate
Reply 5 of 10, by Cyberdyne
I usually use a Pentium 2/3, and use CPUCACHE Disabled for older games. It works perfectly.
I really do not need moslow or some other elaborate TSR slow down program.
And yes, many games have problems with sound detecting and playback in fast computers.
Reply 6 of 10, by 640K!enough
Sometimes, it also helps to set 8- and 16-bit I/O recovery time as high as they will go on such systems, assuming you have such a setting. Try experimenting with different values to see if it helps.
Reply 7 of 10, by Phreeze
have you configured it on IRQ7 ? so games only try to detect the SB on irq7, especially older games when 7 was the standard and not 5
ArGUS Parts list: http://bit.ly/2Ddf89V
Reply 8 of 10, by Cyberdyne
Ok and few games only work in sound blaster pro mode, it the T is set to 4 not 5 as some sources sugest.
Hocus Pocus comes to mind.
Reply 9 of 10, by BitWrangler
Yah, I've come across that, game ignores T5 or T6 but will work with it set to T4
(BLASTER environment variable for ppl having trouble following.)
Reply 10 of 10, by andreja6
I have a T4 card, and have set it to T4... still happens 😒
