DOSBox Compilation Guides
General information and assistance with DOSBox.
Postby DosFreak » 2017-8-30 @ 20:53
The intent of the attached guides is to update the documentation on the DOSBox WIKI:
https://www.dosbox.com/wiki/BuildingDOSBox
Credits:
gandhig (For reviewing the guide and providing corrections and testing)
Qbix
Neozeed (Blog posts and tips via email)
All the people that wrote the guides that I read to make this one.
DOSBOXMingw64.txt
(14.74 KiB) Downloaded 33 times
DOSBOXMINGW.txt
(20.33 KiB) Downloaded 15 times
mingwrt-5.0.1-mingw32-dev-bug2357.zip
(943.84 KiB) Downloaded 9 times
dosboxsvn-10262017-mingw64710-NT351+.zip
(9.26 MiB) Downloaded 15 times
dosboxsvn-10262017-mingw630-NT351+.zip
(8.58 MiB) Downloaded 22 times
DXSDKFEBJune2010forSDL1.2.x.zip
(275.23 KiB) Downloaded 15 times
MINGW64-5.0.2-DXfiles-for-MINGW32.zip
(101.36 KiB) Downloaded 13 times
DOSBOXVisualStudioMultTarget.txt
(29.76 KiB) Downloaded 27 times
DOSBOXVisualStudioIndiv.txt
(38.36 KiB) Downloaded 42 times
vbempj.zip
(125.83 KiB) Downloaded 32 times
Q932590.zip
(206.91 KiB) Downloaded 33 times
SDL_net-1.2.8-NT351-95-NT4forGCC.zip
(587.46 KiB) Downloaded 41 times
dosboxsvn09182017-351tovista.zip
(6.29 MiB) Downloaded 34 times
vc6redistsetup_enu.zip
(1.71 MiB) Downloaded 44 times
User avatar
DosFreak
Re: DOSBox Compilation Guides
Postby DosFreak » 2017-9-21 @ 12:03
COMPILING DOSBOX
https://github.com/aqualung99/dosbox-0. ... 75GLES.txt
https://www.chocolate-doom.org/wiki/ind ... ing_Cygwin
https://github.com/msys2/msys2/wiki/MSYS2-installation
MAC: https://hexeract.wordpress.com/2016/09/ ... cos-sierra
MSVC
Look into compiling from CLI https://doc.libretro.com/compilation/wi ... c-cmdline/
Update VS guides with mingw-w64 guide updates.
Repositories vs zips. Test
Use vbempj.zip for NT3.51
Instructions for 64bit DOSBox (not recommended due to slow dynrec)
If dynamic then list redist as requirement
Updated MSVC guide with MINGW64 guide changes
diff against SDL and DOSBOX for changes? Mabye provide both methods.
Use Mingw with Visual Studio https://stackoverflow.com/questions/156 ... le-project
SDL_NET 1.2.7 vs 1.2.8
VS compiled DOSBox with /MT does not require msvcrt.dll
Command to gather all executables and dlls
Equivalent to "make clean"
Need to verify dependencies work in dosbox
Possible issue with SDL_Sound http://www.vogons.org/viewtopic.php?t=39101&p=354759
Add DOSBox files to package
Precompiled libraries
static link libraries or not?
viewtopic.php?t=3944
PNGLIB PATCH viewtopic.php?f=32&t=53116&p=573451#p573451
Verify SDL_SOUND and other sound libriaries and see if they work.
Comment vs removing issues in dependencies.
For pnflibconf.h bug look into putting in troubleshooting section.
Download free versions of Visual Studio Versions and Platform and Windows SDKs. https://en.wikipedia.org/wiki/Microsoft_Windows_SDK
NT3.51 requirements: MSVCRT
95 requirements: Winsock2, OpenGL, IE4 Active Desktop, MSVCRT
NT4 requirements: IE4 Active Desktop
GIT
GIT vs VisualSVN and TortoiseSVN
Visual Studio 2017 GIT support
https://git-for-windows.github.io/
Relative paths for projects:
If C:\BUILD\Dosbox
then should be able to point to $(ProjectDir)..\whatever or ..\whatever
STATIC LINK TO MSVCRT.dll like MS does for programs that come with Windows?
May have to use /MD with WDDK 2003 SP1 compiler or PSDK 2003 SP1
Windows Server 2003 SP1 Platform SDK https://www.microsoft.com/en-us/downloa ... x?id=12261
or mabye link with the 7600.16385.1 WDK
http://planet.jboss.org/post/fighting_t ... t_dll_hell
https://hero.handmade.network/forums/co ... on_windows
http://bearwindows.zcm.com.au/msvc.htm#c8
OPERATING SYSTEM COMPATIBILITY
COMPILE DOSBOX WITH COMPILERS THAT DO NOT SUPPORT WINDOWS 95
Blackwingcat vcfix
http://blog.livedoor.jp/blackwingcat/ar ... 52362.html
To use:
add to dosbox.cpp
#define WINVER2 0x0400
#include "commonfix.h"
and add commonfix.h to the dosbox\src directory for now.
VS2005 compiled DOSBox
Windows 95 missing:
InterlockedCompareExchange (Fixed with LegacyExtender)
VS2010 compiled DOSBox
Windows 95 missing:
EncodePointer (Fixed with LegacyExtender)
DecodePointer (Fixed with LegacyExtender)
FindFirstFileExA
HeapSetInformation (Fixed with LegacyExtender)
VS2012 compiled DOSBox
Windows 95 missing:
InitializeCriticalSectionEx
EncodePointer
DecodePointer
GetModuleHandleExW
FindFirstFileExW
InitOnceExecuteOnce
SetFilePointerEx
FlsAlloc
FlsGetValue
FlsSetValue
FlsFree
GetTickCount64
CompareStringEx
GetLocaleInfoEx
GetUserDefaultLocaleName
LCMapStringEx
IsValidLocaleName
EnumSystemLocalesEx
MINGW
LOW
Repositories vs zips. Test on mingw32 and mingw64
SDL_NET 1.2.7 vs 1.2.8 OS compatibility
Precompiled libraries? Any point?
DOSBox Debug viewtopic.php?t=3944
QtCreator vs Codeblocks
Check sdl_net and verify if changes for NT 3.51 and 9x are needed.
Check gandhig PM for SSE executables for Windows 95.
Possible mouse issue with SDL 1.2.15 and 9x. Mouse cursor frozen on exiting DOSBox sometimes. Execute dosbox again to unfreeze.
https://sourceforge.net/p/scummvm/bugs/5859/
NT3.50
w32api
winbase.h
getsystemtimeasfiletime
To make a working VICE SDL binary for Windows NT 3.50 the following needs to be done:
- Compile SDL without DX, GL and joystick support:
SDL_config_win32.h
REMOVE:
#define SDL_AUDIO_DRIVER_DSOUND 1
#define SDL_VIDEO_DRIVER_DDRAW 1
#define SDL_VIDEO_OPENGL 1
#define SDL_VIDEO_OPENGL_WGL 1
SDL_config_win32.h
ADD
#define NO_CHANGEDISPLAYSETTINGS 1
SDL.DSP
REMOVE
Directx.h
SDL_dx5audio.c
SDL_dx5audio.h
SDL_dx5events.c
SDL_dx5events_c.h
SDL_dx5video.c
SDL_dx5video.h
SDL_dx5yuv.c
SDL_dx5yuv_c.h
SDL_joystick.c
SDL_joystick_c.h
SDL_mmjoystick.c
SDL_sysjoystick.h
C:\Mingw\msys\1.0\home\XXX\BUILD\DOSBOX\3.50\SDL-1.2.15\include\sdl_config_win32.h
#define SDL_JOYSTICK_DISABLED 1
zips vs version control
SDL - online newer
SDL_net - online newer
sdlsound online newer
flac same
zlib same
libpng same
libogg same
libvorbis same
HIGH
Verify dependencies work in dosbox
Compile automake,gawk,libtool for mingw from here: https://ftp.gnu.org/gnu/
Compile pkg-config for mingw https://pkg-config.freedesktop.org/releases/?C=M;O=D
Procedures for testing:
screenshot CTRL+F5
video capture CTRL+ALT+F5
networking IPX and modem
bin/cue CD audio,flac,ogg,mp3
Remove MSVCRT dependency:
http://nullprogram.com/blog/2016/01/31/
https://stackoverflow.com/questions/730 ... pendencies
LINUX HOST
https://lists.gnu.org/archive/html/ming ... 00045.html
Cross compile Linux to Windows
It is also possible to cross compile from Linux to windows using the MinGW cross tools and even to run the test suite under Wine, the Linux/*nix windows emulator.
On Debian and Ubuntu systems, these cross compiler tools can be installed by doing:
sudo apt-get mingw32 mingw32-binutils mingw32-runtime wine
Once these tools are installed its possible to compile and test by executing the following commands, or something similar depending on your system:
./configure --host=i586-mingw32msvc --target=i586-mingw32msvc --build=i586-linux
make
make check
DOSBOX COMPILED WITH VS2008 (Runs on NT3.51)
Windows NT 3.5 SP0
KERNEL32.DLL
GetSystemTimeAsFileTime
USER32.DLL (Need to remove fullscreen support in SDL)
ChangeDisplaySettingsA
EnumDisplaySettingsA
WINMM.DLL (Need to remove joystick support from SDL)
joyGetPosEx
Missing APIs in Windows NT 3.10:
KERNEL32.DLL:
CompareStringA (only CompareStringW exists)
EnumSystemLocalesA (only EnumSystemLocalesW exists)
GetLocaleInfoA (only GetLocaleInfoW exists)
GetStringTypeA (only GetStringTypeW exists)
GetVersionExA (only non-Ex version GetVersion available)
LCMapStringA (only LCMapStringW exists)
USER32.DLL
CreateIconFromResourceEx (only non-Ex version CreateIconFromResource available)
GetKeyboardLayout
LoadImageA (only LoadBitmapA exists)
MapVirtualKeyExA (only non-Ex version MapVirtualKeyA available)
ToAsciiEx (only non-Ex version ToAscii available)
WINMM.DLL
joyGetPosEx (only non-Ex version joyGetPos available)
GDI32.DLL
CreateDIBSection
GetDeviceGammaRamp
SetDIBColorTable
SetDeviceGammaRamp
OLE32.DLL (whole file is missing in NT 3.10 retail and SP3)
CoInitialize
BUILDBOT
Need to look into either a #define to remove ActiveDesktop or a fallback if no Active Desktop found.
THIRD PARTY PATCHES
viewtopic.php?f=32&t=35256&p=301919#p301814
https://blogs.msdn.microsoft.com/chuckw ... rtain-age/
Pixel Perfect Patch
https://roadtoalm.com/2013/10/22/use-vi ... cal-files/
C:\Program Files (x86)\Microsoft Visual Studio\2017\Professional\Common7\IDE\CommonExtensions\Microsoft\TeamFoundation\Team Explorer\vsdiffmerge.exe
http://gnuwin32.sourceforge.net/packages/patch.htm
SDL2 on Windows 2000
https://www.tapatalk.com/groups/win2kga ... t1073.html
viewtopic.php?f=32&t=34770&start=60#p537272
MIDI
https://www.dosbox.com/wiki/MIDI_software_devices
viewtopic.php?f=33&t=55993
MUNT Windows 98
A multi-platform software synthesiser emulating (somewhat inaccurately) pre-GM MIDI devices such as the Roland MT-32, CM-32L, CM-64 and LAPC-I. In no way endorsed by or affiliated with Roland Corp.
viewtopic.php?f=40&t=55981
OPL3
https://sourceforge.net/p/dosbox/patches/270/
viewtopic.php?f=41&t=49327
XBRZ
viewtopic.php?f=41&t=34125
NE2000
https://sourceforge.net/p/dosbox/patches/238/
VSYNC
viewtopic.php?f=41&t=35535
viewtopic.php?t=37148
Check
https://sourceforge.net/p/dosbox/patches/125/
Need to categorize third party patches:
What are the "necessary" third party patches?
cross-platform
Never will be crossplatform
Already in DOSBox
Never will be in DOSBox
etc
PIXELPERFECT
viewtopic.php?f=41&t=49160&hilit=pixel+perfect&start=420
https://git-scm.com/download/win
Install
Add C:\Program Files (x86)\Git\usr\bin to path variable
Put "diff" in dosbox folder
Run patch -p0 < patchfile
http://gnuwin32.sourceforge.net/packages/rpl.htm
VS2008 does not like "round" identifier. VS2010 should work.
Patch should work with Mingw which works on less than XP.
viewtopic.php?f=41&t=36342
WINDOWS ONLY
http://www.si-gamer.net/gulikoza/
Need to find latest software ver of xbrz (Non-GL)
Shader support for DOSBox Mac,Windows,Lunux. Which patch?
https://www.gamingonlinux.com/wiki/Buil ... rom_source
https://lists.freedesktop.org/archives/ ... 00497.html
https://mesamatrix.net/
viewtopic.php?f=32&t=49999&start=20
https://www.dosbox.com/wiki/Cuesheet
viewtopic.php?f=31&t=41610
https://www.dosbox.com/wiki/connectivity
http://gadgets.itwriting.com/2158-getti ... ourse.html
https://web.archive.org/web/20160131005 ... index.html
https://sourceforge.net/p/dosbox/patches/260/
OLD
VISUAL STUDIO
Link-time Code Generation
Whole Program Optimization
COMPILERS
VISUAL STUDIO
OFFICIAL
Visual Studio 2003 95-98-NT4-2000
Visual Studio 2005 NT4-98-2000 (NT4 if /MT set)
Visual Studio 2008 NOSP 2000+
Visual Studio 2008 SP1 XP+ (Possibly Windows 2000 with KB816542 and PE header modified)
LIBRARIES
COMPRESSED AUDIO SUPPORT
viewtopic.php?f=32&t=50077
https://www.dosbox.com/wiki/Building_DOSBox_with_MinGW
Game Acronym List
DosBox CVS Builds
DosBox Feature Request Thread
DosBox FAQ
PC Game Compatibility List
"Who's got time to read all the way down to the bottom of an email?"
User avatar
DosFreak
Postby DosFreak » 2017-9-22 @ 13:03
Got Mesa 7.5.1 to work on Windows 95.
7.10.3 is the last ver to support Visual Studio. 6-13-2011 OpenGL 2.1
Download: https://mesa.freedesktop.org/archive/ol ... 7.x/7.5.1/
Compile with VS2008 and LegacyExtender
EDITVERSION from LegacyExtender should work if not then use VS2005 EDITBIN
EDITBIN from VS2005 C++ Command prompt "editbin /subsystem:windows,4.00 /osversion:4.0 opengl32.dll"
Copy opengl32.dll to quake 2 directory to test.
https://mesa.freedesktop.org/archive/ol ... .x/7.10.3/
https://wiki.qt.io/Cross_compiling_Mesa_for_Windows
https://wiki.qt.io/MesaLlvmpipe
https://github.com/florianlink/MesaOnWindows
OTHER
EXEVersion may work: http://louis.steelbytes.com/vs2008_vs_win40.html
https://fdossena.com/?p=mesa/build.frag
https://stackoverflow.com/questions/178 ... 7-mesa-9-1
MESA
https://sourceforge.net/projects/msys2/ ... INGW/i686/
https://sourceforge.net/p/mingw-w64/bugs/599/
https://github.com/Alexpux/MINGW-packages/issues/2282
https://github.com/pal1000/mesa-dist-win
http://forums.thedarkmod.com/topic/1786 ... ntry391478
Possible issue with MSYS2 and GCC. Works fine with MSVC
https://github.com/Alexpux/MINGW-packages/issues/2089
mingw-w64-i686 standalone with dwarf exceptions and posix threading
Possibily fixed in GCC 7.2.0
Game Acronym List
DosBox CVS Builds
DosBox FAQ
User avatar
DosFreak
Postby DosFreak » 2017-10-06 @ 18:37
HXRT & HXGUI
PREREQUISITES
MEMORY
If you want to use Dynamic core or use higher than 16mb of memory in DOSBox then you'll need more than 64mb of memory on your host system.
If you have 64mb or less then only normal core and 16mb of memory can be used in DOSBox.
DOSBOX
Download my 3.51 or 95 builds of DOSBox
HXRT & HXGUI
https://sourceforge.net/projects/hx-dos/
https://web.archive.org/web/20140904175 ... de/HX.html
http://sound-dos.ucoz.ru/load/new_hxdos ... 17/1-1-0-8
hxrt217.zip
hxgui217.zip
HIMEMX
*If OS is less than Windows 95 then use HIMEMX or mabye you can use HIMEM.SYS from Windows 95+.
MSVCRT
Download from this thread or Windows 2000 SP4
INSTALL
HXRT & HXGUI
Unzip both into the same folder c:\HX
Add "C:\HX" to your PATH
DOSBOX
Extract DOSBox to C:\DOSBOX
MSVCRT
Copy MSVCRT.DLL to C:\DOSBOX
Copy the following files from Windows 95 C:\Windows\System to C:\DOSBOX
CRTDLL.DLL
GLU32.DLL
OPENGL32.DLL
DOSBOX CONFIGURATION SETTING FOR MAXIMUM PERFORMANCE
fullscreen=true
fullresolution=original
output=surface
Core=dynamic
cpu=pentium_slow
cycles=max
scaler=none
memory=63
machine=svga_s3
TROUBLESHOOTING
VIDEO
If you only get a black screen when loading DOSBox then verify that you have not exited Windows and then tried to start DOSBox. Boot straight to DOS instead.
INPUT
DOSBox with HXRT & HXGUI seems to have issues with the mouse
BENCHMARKS
DOSBox running quake on the host
210 320x200
70 800x600
QUAKE running in DOS under vmware
*fps numbers vary significantly
377 320x200
233 800x600
167 1024x768
DOSBox running quake under hxrt in DOS under vmware
180 320x200
60 800x600
40.7 1024x768
Between DOSBox in DOS (VMWARE) vs DOSBox on the host there isn't much of a difference in speed.
Between Quake in DOS (VMWARE) vs Quake in DOSBOX using HXRT in DOS (VMWARE) there is a big difference.
Game Acronym List
DosBox CVS Builds
DosBox FAQ
User avatar
DosFreak
Postby DosFreak » 2017-10-30 @ 23:38
Non-DOSBox. CMOV theory with Mingw 4.6+ versions and libraries. True or false? Is objdump accurate? Not relevant for DOSBox but possibly for other projects.
Consolidation of Ryzen posts
NOT RELEVANT TO COMPILING DOSBOX BUT USEFUL FOR CMOV RESEARCH
MANUAL COMPILE OF GCC
Source code for gcc 464:
https://ftp.gnu.org/gnu/gcc/gcc-4.6.4/
1. tar xzf gcc-4.6.4.tar.gz
2. rename gcc-4.6.4 to gcc
2b. Originally ran 3-step bootstrap process for native build, but instead save time and do 1-step for testing
3. cd gcc
4. This was the original configure line, but I don't know yet whether PPro instructions are emitted from this build. Best to specify architecture explicitly in this line and also verify in code that no CMOV code is enabled.
./configure --prefix=$HOME/gcc --enable-languages=c,c++ --disable-sjlj-exceptions --with-dwarf2 --disable-win32-registry --enable-version-specific-runtime-libs --build=mingw32 --prefix=/mingw --disable-libquadmath --disable-libgomp --disable-nls
5. make
6. make install
Source code:
ftp://gcc.gnu.org/pub/gcc/infrastructure/
gmp-6.1.2.tar.bz2
mpfr-3.1.5.tar.gz
mpc-1.0.3.tar.gz
Built the above three libraries using mingw32/gcc462/binutils222.
1. configure shared libraries of gmp/mpc/mpfr for /mingw
./configure --enable-shared --disable-static --prefix=/mingw
3. make; make install
MANUAL COMPILE OF MINGW GCC
https://sourceforge.net/projects/mingw/ ... c-4.8.1-4/
https://sourceforge.net/projects/mingw/ ... tils-2.28/
https://sourceforge.net/projects/mingw/ ... rt-3.21.1/
gcc-c++-4.8.1-4-mingw32-dev.tar.lzma
gcc-c++-4.8.1-4-mingw32-bin.tar.lzma
gcc-core-4.8.1-4-mingw32-bin.tar.lzma
gcc-core-4.8.1-4-mingw32-dev.tar.lzma
binutils-2.28-1-mingw32-bin.tar.xz
libiberty-2.28-1-mingw32-dev.tar.xz
binutils-2.28-1-mingw32-dev.tar.xz
mingwrt-3.21.1-mingw32-dev.tar.xz
gcc-c++-4.8.1-4-mingw32-dll.tar.lzma (C++ runtimes)
gcc-core-4.8.1-4-mingw32-dll.tar.lzma (C runtimes)
The C/C++ runtime files (*.dll) contain PPro instructions but linked staticly then Pentium Pro instructions not included
C++ 11 threading https://github.com/meganz/mingw-std-threads
GCC 4.62 and libraries may not have PPro instructions
MANUAL COMPILE OF MINGW GCC DEPENDENCIES
These are the dependencies in the case of a manual installation of them:
GMP 6.1.2
https://sourceforge.net/projects/mingw/ ... gmp-6.1.2/
gmp-6.1.2-2-mingw32-dev.tar.xz
libgmp-6.1.2-2-mingw32-dll-10.tar.xz
MPFR 3.1.5
https://sourceforge.net/projects/mingw/ ... pfr-3.1.5/
mpfr-3.1.5-1-mingw32-dev.tar.xz
libmpfr-3.1.5-1-mingw32-dll-4.tar.xz
MPC 1.0.3
https://sourceforge.net/projects/mingw/ ... mpc-1.0.3/
libmpc-1.0.3-1-mingw32-dll-3.tar.xz
mpc-1.0.3-1-mingw32-dev.tar.xz
Testing with gcc v493 from here;
https://sourceforge.net/projects/mingw/ ... c-4.9.3-1/
gcc-4.9.3-1-mingw32-src.tar.xz
I recall that the earlier gcc versions have a ready-made configure system, but v493 doesn't. Here is a potential configure line for gcc v493 (--prefix= should be changed accordingly):
./configure --prefix=$HOME/gcc --enable-languages=c,c++ --disable-sjlj-exceptions --with-dwarf2 --disable-win32-registry --enable-version-specific-runtime-libs --build=mingw32 --prefix=/mingw --disable-libquadmath --disable-libgomp --disable-nls --disable-bootstrap --host=mingw32 --with-tune=i386 --with-arch=i386
make install
OLD
The bug report for gcc 4.7 branch shows at least some of the problem in i386.h:
X86_ARCH_CMOV
#define TARGET_CMOV
#define TARGET_CMOVE
This is one section of code which refers to activation of the PPro instruction set. I haven't searched for other examples nor in other branches yet. If the PPro issue is difficult to solve, then these targets may be defined away in the code for testing.
Edit: one possibility is that the GMP library is the cause along the gcc 4.6 branch. Found this in the configure log for it: march=pentium4. In the source code of gcc 4.6.4, couldn't find any examples of *CMOV*, but the GMP library had many references to it.
Perhaps defining "HAVE_HOST_CPU_pentium" in GMP configure.ac will at least fix the issue in GMP?
Edit 2: it is probably necessary to confirm that objdump is producing the correct output by trying another tool and compare the results.
For example, a Quake 2 binary from 1998 shows a single fcmovu instruction from the PPro set. It was presumably built by Visual C++ 5.0 which does have the capability to emit the PPro set.
Edit 3: verified that the gcc 464 custom build had PPro instructions in libgmp while the official gcc 46 version did not. However, the CMOV patch discussed in the previously posted gcc bug report was applied to gcc 464. Also, verified that i386.c/h are the main parts of gcc 464 which have references to the PPro instructions.
Edit 4: tried to verify the PPro instructions predicted by objdump against those generated by gcc itself (gcc -S option). The result was that PPro instructions were already in "libdxguid.a", a third-party available mingw32 library. That probably explains a previous finding of PPro instructions when building with the default gcc 4.6 of mingw32. Requires more testing.
Edit 5: the gcc 3.4 finding was probably a result of false detection of cmovs by a djgpp version of objdump. This version of objdump also detected cmovs in software compiled by gcc versions before the PPro was supported.
Game Acronym List
DosBox CVS Builds
DosBox FAQ
User avatar
DosFreak
Postby DosFreak » 2017-11-21 @ 21:02
ISSUE
When DOSBox (using Directx) is executed on a 9x system then if you try to move the mouse over the DOSBox window then it will either freeze or move erraticly (not captured yet). If captured the mouse works fine in DOSBox.
Also if the mouse is captured by DOSBox and you exit then the mouse will be frozen, you must uncapture the mouse before exiting DO
SDL_dx5events.c and SDL_sysevents.c handle the mouse movements.
SDL_dx5events.c MIGHT be the cause of the mouse issue
SDL_sysevents.c MIGHT be for mouse usage inside DOSBox.
Really both work together so if one is modified the other must be too....if you know what you're doing.
If using DOSBox with WINDIB then no issue.
Issue occurs with SDL 1.2.14 and SDL 1.2.15.
Replacing
C:\Mingw\msys\1.0\home\XXX\BUILD\DOSBOX\95-NT4\SDL-1.2.15\src\video\windx5
SDL_dx5events.c in SDL 1.2.15 with the SDL_dx5events.c from SDL 1.2.13
"fixes" the issue where the mouse doesn't work on the host.
or you can just add the following to SDL_dx5events.c instead:
Replace Lines #373-377 with the following from SDL 1.2.13:
#301 /* If we are in windowed mode, Windows is taking care of the mouse */
#302 if ( (SDL_PublicSurface->flags & SDL_OPENGL) ||
#303 !(SDL_PublicSurface->flags & SDL_FULLSCREEN) ) {
#304 return;
#304 }
Remove Line 551 extra bracket:
#547 if ( xrel || yrel ) {
#548 post_mouse_motion(1, xrel, yrel);
#549 }
#550
#551 }
This then causes the mouse to not work inside DOSBox
To fix that then modify:
SDL-1.2.15\src\video\wincommon\sdl_sysevents.c
(See file)
So the SDL 1.2.15 9x minimal package I put together is still the latest I've got. Still looking at it today and it seems like there's not too much more I can do to minimize the changes.
What I'd like to do is fix the bug but I don't think I understand the code enough to do that.
Windows 95-98 with sdl_videodriver=directx
SDL 1.2.15 - When mouse is uncaptured and dragged over the dosbox windown then the mouse may not move or will move all over the screen. When mouse is captured the mouse works fine in dosbox in both window and fullscreen. If you quit DOSBox while the mouse is captured then the mouse will be frozen.
SDL 1.2.15 9x minimal - Same behavior as 1.2.13. Mouse works fine in windowed or full screen in dosbox. Mouse works fine uncaptured.
To my uneducated eyes it looks like mabye SDL is confused about the mouse focus or capture so when the mouse is on the screen then it's captured but mabye it doesn't think that it is? When you quit dosbox then SDL never releases it back to Windows? Mabye the reason it works fine in Windows 2000+ is due to a security feature in the OS that overrides the bug in SDL?
Debating using current fix or just compiling 9x builds with WINDIB only. Don't think there is a downside.
Links:
https://icculus.org/pipermail/quake3-co ... 01365.html
http://diehardwolfers.areyep.com/viewtopic.php?p=89401
https://github.com/spurious/SDL-mirror/tree/SDL12
SDL 1.2.14
Most promising
https://github.com/spurious/SDL-mirror/ ... 266ca8ab3a
PRIOR COMMIT
https://github.com/spurious/SDL-mirror/ ... 27ee36aec4
git clone https://github.com/spurious/SDL-mirror.git SDL12
cd SDL12
git checkout 140163c34e
OLD
Sept 27, 2009
https://github.com/spurious/SDL-mirror/ ... 157b87e330
https://github.com/spurious/SDL-mirror/ ... e1c1435608
https://github.com/spurious/SDL-mirror/ ... 62b82512e3
https://github.com/spurious/SDL-mirror/ ... d778e2b937
SDL-1.2.15 9x-Minimal.zip
(16.76 MiB) Downloaded 8 times
SDL-1.2.15 for 9x-toomanymods.zip
(16.71 MiB) Downloaded 8 times
Game Acronym List
DosBox CVS Builds
DosBox FAQ
User avatar
DosFreak
Postby DosFreak » 2017-11-30 @ 23:56
TODO:
Decide on SDL 1.2.15 for 9x or WINDIB only for 9x (Would still leave a TODO: High for fixing SDL on the list tho)
Update guide and mingwrt package with latest patch by Keith from using diff file https://sourceforge.net/p/mingw/bugs/2357/
Check SDL_Sound and dependencies
Recompile dosbox for mingw and mingw-w64 and post builds
https://virtuallyfun.com/2018/01/21/min ... sing-dlls/
-static-libstdc++ -static-libgcc -Wl,-Bstatic -lstdc++ -lpthread -Wl,-Bdynamic
No luck from ioquake3 person that submitted dinput patch in SDL. We're on our own.
GCC3.4.5(MinGW 5.1.6) works on Windows 95
gdb 6.3-2 Works on Windows 95
Game Acronym List
DosBox CVS Builds
DosBox FAQ
User avatar
DosFreak
Postby DosFreak » 2017-12-06 @ 18:35
I've been sick since coming back from Thanksgiving. Feel alot better now but haven't felt up to working on the guide, hopefully thursday or friday I can get back to it.
Game Acronym List
DosBox CVS Builds
DosBox FAQ
User avatar
DosFreak
Postby gandhig » 2017-12-10 @ 20:11
DosFreak wrote:No luck from ioquake3 person that submitted dinput patch in SDL. We're on our own.
For some reason unknown to me, the Windows' "ClipCursor" function called by the SDL's "post_mouse_motion" function has no effect on the cursor movement inside the dosbox main text window(directx driver, windowed mode) in Win95.
The issue is not there with SDL 1.2.13, probably due to the handling of the mouse by Windows itself(when the SDL application is in windowed mode) rather than by SDL, as is the case with ver 1.2.15.
Trying still to identify the issue.
User avatar
gandhig
Postby DosFreak » 2017-12-10 @ 22:23
You were able to state the issue alot more eloquently than I could. heh
According to:
https://msdn.microsoft.com/en-us/library/ee418864.aspx
http://xboxforums.create.msdn.com/forums/t/108722.aspx
https://code.msdn.microsoft.com/windows ... iscussions
https://s547.neocities.org/mouse.html
it's not recommended to use dinput for mouse and keyboard...
DirectInput is a set of API calls that abstracts input devices on the system. Internally, DirectInput creates a second thread to read WM_INPUT data, and using the DirectInput APIs will add more overhead than simply reading WM_INPUT directly. DirectInput is only useful for reading data from DirectInput joysticks; however, if you only need to support the Xbox 360 controller for Windows, use XInput instead. Overall, using DirectInput offers no advantages when reading data from mouse or keyboard devices, and the use of DirectInput in these scenarios is discouraged
Wonder if the ioquake3 commit only benefited ioquake3.
Game Acronym List
DosBox CVS Builds
DosBox FAQ
User avatar
DosFreak
Postby DosFreak » 2017-12-11 @ 00:58
https://github.com/spurious/SDL-mirror/ ... diff=split
https://hg.libsdl.org/SDL/rev/a6f635e5eaa6
https://hg.libsdl.org/SDL/log/4171
sdl_dx5events.c
/* Construct a 1 pixel square RECT that is used to confine the cursor
+ * pointer to a specific pixel using ClipCursor. This is used in
+ * preference to SetCursorPos as it avoids the cursor jumping around as
+ * both the OS and SDL attempt to move it simultaneously. */
hmmm so mabye it's not tracking the coordinates when using the DX driver on 9x when in non relative mode. I'm assuming relative is when the mouse is captured since it works fine inside dosbox. (Mouse cursor hidden and stuck in center of screen).
sdl_sysmouse.c
sys_sysevents.c
Game Acronym List
DosBox CVS Builds
DosBox FAQ
User avatar
DosFreak
Postby gandhig » 2017-12-11 @ 19:01
DosFreak wrote:hmmm so mabye it's not tracking the coordinates when using the DX driver on 9x when in non relative mode. I'm assuming relative is when the mouse is captured since it works fine inside dosbox. (Mouse cursor hidden and stuck in center of screen).
Yes, the non-relative mode seems so, but needs to be re-verified at my end('mouse_relative' variable). I'm assuming that you didn't refer to the 'relative' variable used inside the SDL_PrivateMouseMotion function.
That aside, observations(subject to edit, later) as per my current understanding are,
Code: Select all
a) In dosbox 'windowed' as well as 'fullscreen' mode (Win95), the mouse cursor movement inside the SDL Window(i.e. dosbox Z prompt) is taken care of by the SDL's post_mouse_motion function, which in turn utilizes Windows' ClipCursor function to supposedly move the Cursor to the calculated position inside the dosbox window, based on the inputs received from the actual hardware & reported through the Direct Input interface/mouse device object. But ClipCursor doesn't seem to be working. However the cursor position as per the actual movement is properly getting updated in the SDL mouse structure internally with the correct screen/client coordinates. The above is obviously with 'no grab'.
b) Under Win7, the ClipCursor function works properly inside the SDL window with each mouse movement.
c) Under Win7, the mouse motion events generated are also somewhat different compared to Win95. In case of Win7, 'handle_mouse' function is not called when the cursor movement is outside the window and the dosbox window isn't 'in focus' or 'active'. However under Win95, the function gets called even when the dosbox window is not active and the mouse is moved outside the window.
Edit(12.12.17):
If I just replace the ClipCursor(&trap) with SetCursorPos(cursor.x, cursor.y) in line 344 of SDL_dx5events.c, mouse does move inside the dosbox window and also doesn't get stuck on exit(not captured). However, as warned in the comments, the mouse movement sort of resembles a tug of war. I will try till this weekend and then throw the towel.
User avatar
gandhig
Postby DosFreak » 2017-12-14 @ 02:52
Still alive! No longer sick. Haven't done any work on the guide but I have done alot of work managing my inventory in Divine Divinity Enhanced.....
gandhig,
Let me know when you call it quits and we can decide on best method to go with:
1. Revert to minimal changes to 1.2.13 code for mouse
2. Solution found for 1.2.15 mouse issue (yeah right)
3. Revert all commit changes for mouse back to 1.2.13 (likely unnecessary)
4. Windib only for 9x (not ideal but probably no one cares)
If no #2 found then will keep on the list for someone smarter than us.
Game Acronym List
DosBox CVS Builds
DosBox FAQ
User avatar
DosFreak
Postby gandhig » 2017-12-14 @ 07:08
DosFreak wrote:gandhig
Sure, mostly by the end of this weekend.
I'm presently experimenting with the programs in 'test' SDL directory instead of dosbox. The test programs fail too with directx driver.
User avatar
gandhig
Postby DosFreak » 2017-12-14 @ 15:09
Game Acronym List
DosBox CVS Builds
DosBox FAQ
User avatar
DosFreak
Postby gandhig » 2017-12-17 @ 17:08
Ok, I give up.
Contrary to my earlier statement, the ClipCursor function does work as I'm getting proper return values when checked in gdb.
The return value of ClipCursor in Win7 is different w.r.t Win95 in that under Win7 it returns only '1' (EAX value) on success, whereas in Win95 the return value observed in EAX register is the X coordinate of mouse. If I manually change the 'trap' rectangle which is fed as the argument to the ClipCursor function, the cursor does get restricted to the changed rectangle. But it doesn't happen during the normal run of the SDL test program (threadwin.exe) with directx driver. My incomplete understanding leads to the following possibilities(not in any particular order) & observations:
a)_TrackMouseEvent points to SDL's WIN_TrackMouseEvent in Win95, but Win7 has its own TrackMouseEvent(takes care of mouse leaving the SDL window). Incompatibility with new mouse handling code in SDL-1.2.14/15??? Should not matter as it is responsible for only tracking as to when the mouse leaves the window???
b) Direct Input implementation in Win95??? As per the links you referred, the direct input's mouse and keyboard interfaces are wrappers around WM_MOUSEMOVE messages under later OS versions (since WinXP), so there is no issue there.
c) Too many WM_TIMER messages(due to TrackMouseEvent???) observed during the handling of Window messages at the start of DX5_CheckInput function under Win95 (timer resolution ???)
d) Under Win95, once the mouse enters the client area of the SDL window, say, from the top (i.e client coordinate SDL_MouseY=0, at_edge is true, cursor changes to black...), further mouse movement(left/right) in the X-axis is fine as the OS is taking care of the motion. Just moving the mouse one step down(i.e. client coordinate SDL_MouseY=1, at_edge is false..), something happens that makes the cursor get stuck, though this initial one step movement does happen(again courtesy of OS probably). After that, no movement. However if we keep on moving the mouse,say, towards the bottom, it does get released once enough movements in the Y-axis get accumulated such that the mouse cursor warps out of the bottom of the SDL window/DOSBox Z prompt window. Similarly if we make small upwards movement of the mouse(w.r.t SDL_MouseY=1) towards the top, it immediately gets released outside the SDL window, off the top.
Would it be better to leave a note in the guide with all the possible options and let the users decide as per their requirements? I'm not sure about the best option, that's why.
User avatar
gandhig
Postby DosFreak » 2017-12-17 @ 17:51
Thanks for looking into it.
Think I'll put into the guide how to revert back to the SDL 1.2.13 mouse code if 9x DirectInput support is not needed in a window and also mention it works fine in 9x with WINDIB if whoever compiled doesn't want to modify SDL.
Issue with reverting back to 1.2.13 code for SDL would be that if multiple SDL projects are compiled and someone forgets then they would be using that code so may need to redirect those libraries elsewhere and point dosbox during compilation.
Then at the bottom of the guide I'll provide further details on the issue.
I believe the only reason the commit was made in SDL was probably for high DPI mice in ioquake3 which no one has ever complained about high dpi mouse issues with DOSBox so no issue with removing the code.
According to this dinput was dropped for mouse in SDL2 (haven't verified) so makes even more since to use the 1.2.13 code.
https://discourse.libsdl.org/t/please-r ... dows/20125
I'll ask Qbix his thoughts as well.
Game Acronym List
DosBox CVS Builds
DosBox FAQ
User avatar
DosFreak
Postby DosFreak » 2017-12-18 @ 02:11
This is interesting, not for this specific issue but info on walking through a similar issue:
https://discourse.libsdl.org/t/win10-fa ... ng/23526/3
Provide build environment via google drive.
Game Acronym List
DosBox CVS Builds
DosBox FAQ
User avatar
DosFreak
Postby DosFreak » 2017-12-24 @ 05:33
Plan to resume after New Years, likely after the first weekend of Jan since I have to work that weekend. Current goal is to get vanilla DOSBox finalized for mingw32 and 64. Then update the VS guide with the latest changes and then do another guide for compiling when using Linux.
Review guides for streamlining and to make things easier.
After that then look into 3rd party patches and try to setup MacOS in a VM.....mabye.
Game Acronym List
DosBox CVS Builds
DosBox FAQ
User avatar
DosFreak
Postby gandhig » 2018-1-03 @ 18:59
The closest I got to a workaround to the erratic mouse movement issue with 'directx' driver is by modding the code from line nos. 324 to 327 of SDL_dx5events.c(just expanding the 'trap' rectangle slightly):
Code: Select all
    Line No:324:      trap.left = cursor.x - 1;
    Line No:325:      trap.top = cursor.y - 1;
    Line No:326:      trap.right = cursor.x + 2;
    Line No:327:      trap.bottom = cursor.y + 2;
'Mouse stuck on exit' issue resolved by adding 'ClipCursor(NULL)' in DX5_DestroyWindow function after line no. 990 of SDL_dx5events.c
Code: Select all
    Line No:990:      DX5_DInputQuit(this);
    Line No:991:      ClipCursor(NULL); /* free the stuck cursor while exiting in Win9X(windowed & grab mode = off) */
    Line No:992:      /* Destroy our window */
Not pretty, but this is the best I can do presently.
SDL_dx5events.c
Modded file, more or less as a workaround for 'erratic mouse movement' and 'cursor stuck on exit' while using directx driver in windowed mode with no grab under Win9X
(27.43 KiB) Not downloaded yet
BTW, does anyone have old Win32 SDK for windows 95? I tried searching, but couldn't find it.
User avatar
gandhig
Return to DOSBox General
Who is online
Users browsing this forum: Yahoo [Bot] and 0 guests
