First post, by RrnR
I have the following problem:
- I start DOSBox
I Alt-Tab to another window
I Alt-Tab back to DropBox window
At this point, the prompt will show a rapid succession of filenames - what is actually happening is that DosBox is imagining the TAB key is being pressed repeatedly - I have verified this by loading an editor in the DosBox. When I Alt-Tab out and then in again, the file loaded in the editor starts to fill up with tabs
This seems to happen reliably. It is doubtless some problem with the keyboard emulation, but does anyone know how to fix it? I use Alt-Tab a lot for breaking out of a DOSBox that has captured the mouse.
