First post, by 386SX
I'm trying some different 20pin power supply on a 24pin motherboard (supporting dual core intel / ddr2) leaving the last 4 pin of the mobo connector obviously open. I read somewhere that beside some heavy power requirements it should still boot so I used a 1,65ghz low power dual core cpu but no way, the fan seems to move a bit and then it stops.
Do you think I still need a 24pin power supply or I can use these P4 20pin ones anyway? Or I need the converter cable?
Thank
Reply 6 of 9, by .legaCy
The 4 pin power connector that sits right next to the cpu is connected right?
Just to be sure that is connected properly you can wiggle it in a little bit.
Is there anything that may cause short circuits like those metal stand offs in the case?
Reply 7 of 9, by 386SX
The connector is stable and the mobo is outside the case with just the cpu and ram. Maybe some components failed and causing this?
Reply 8 of 9, by SW-SSG
It does sound like something on the board is shorted.
Without the 4-pin ATX12V attached, it should power on (fans spinning and etc) but not POST... at least in my experience.
Reply 9 of 9, by .legaCy
Well maybe failing mosfets or mosfet drivers, if you can diagnose the vrm part of the board.
This happened to me twice, one was a shorted motherboard(thankfully the psu protection prevented the motherboard to be fried, removing the short brought it back) and other was bad fets on the board.
