Searching for BIOS FIC VA503+ je4333apm.zip
Postby LeFlash » 2017-12-07 @ 14:07
Hello,
someone having a copy of je4333apm.zip?
Its a modified beta-bios from FIC for the VA503+ with K6-III+ Support and up to 60GB IDE drives.
Can't find a copy of it anywhere on the net :(
Kind regards!
LeFlash
Re: Searching for BIOS FIC VA503+ je4333apm.zip
Postby cyclone3d » 2017-12-07 @ 17:15
I'm not finding the APM version anywhere, but the standard je4333 version is available.
Is there a specific reason you want the APM only version (ACPI option rom stripped out)? Only reason I see for that is if you want to run XP.
The regular version supports K6-2+/K6-3+ CPUs as well as large drives.
JE4333.ZIP
(124.76 KiB) Downloaded 10 times
User avatar
cyclone3d
Postby LeFlash » 2017-12-07 @ 17:19
The only difference is the stripped ACPI? Ok, i can do this myself.
Thank you for this information!
Got hold of this board today and was immediately happy because i used this board a lot that time.
It's revision 1.0A and has a 4.7k resistor between Vss and NMI on the socket, i'm not sure if that's a factory or user mod.
LeFlash
Postby cyclone3d » 2017-12-07 @ 17:40
Yeah, only difference is ACPI stripped out from what I could find... at least that is what the person that made the original modded BIOS said in the posts I found.
User avatar
cyclone3d
Who is online
Users browsing this forum: BinaryDemon, BLEXBot [Bot], Deksor, Xicor and 5 guests
