Re: What retro activity did you get up to today?
Postby .legaCy » 2017-12-07 @ 22:54
I got this AT keyboard to go with my 486 build(sadly it will not be a model m, but it should be silent)
So i disassembled the whole keyboard and all the plastic parts went to the laundry room with me so i can clean them pretty good.
Hopefully tomorow will be a sunny day so i can retr0bright the hell out of this badly yellowed keybard.
I think that it will require at least 8 hours of direct sun with peroxide to remove this yellowing.
User avatar
.legaCy
Postby bjwil1991 » 2017-12-07 @ 23:19
.legaCy wrote:I got this AT keyboard to go with my 486 build(sadly it will not be a model m, but it should be silent)
That's a lot of yellowing. Someone must've smoked by the keyboard or too much UV rays.
C64, WheelWriter 10 Series II QuietWriter 8, Pack-Mate 28 Plus, K6-2/300, Pavilion N3350, iMac G3 & G4, Socket 462, 2x Inspiron 600m, Athlon 64, Dimension 4550 & E510, ThinkPad R40, Presario C700, ASUS X54C, Raspberry Pi B+, 2B-3B+, Custom FX-6300
User avatar
bjwil1991
Postby badmojo » 2017-12-07 @ 23:24
Bancho wrote:Started putting this together today. Saw this M-ATX Cheiftec case on ebay and it looked perfect for the build i wanted to put together. It really is a compact case.
I love that case! Small is good, and it'll look meaner still with that CD changer in it.
If it's broke, then fix it!
User avatar
badmojo
Postby Mister Xiado » 2017-12-08 @ 03:35
Anaxagoras wrote:this computer is only 14 years old, is not time yet. :depressed:
Au contraire, it is the perfect time, for a great many motherboard made in the early 2000s have the capacitor plague. I have an ASUS board in the basement full of dead capacitors, but as I have zero use for a Pentium 4 system, I'd sooner take it to the range and feed it to my AR-15 than bother replacing the caps.
Image - Where it's always 1992 (or so).
User avatar
Mister Xiado
Postby luckybob » 2017-12-08 @ 03:42
Hell, I have a late Intel 775 board here that needs some new caps. So it can happen to all computers, at any time. 98-02 is like the dark ages. I just replace those as a matter of course.
User avatar
luckybob
Postby .legaCy » 2017-12-08 @ 07:25
Well, this is the most yellowed piece of plastic that i ever touched, the num/caps/scroll lock is almost browned, the inside was covered in a thin black layer of dust too, i also gave the rubber mat a good wash, and the scuffs went out with a good scrubbing with sapolio radium(a kind of creamy soap that is slight abrasive that is sold in my country)
UPDATE: Heat + peroxyde is a really dangerous treatment, the plastic case got all bent up and i lost this keyboard.
Oh well, looking on the bright side, it wasn't one ibm model m.
User avatar
.legaCy
Postby oeuvre » 2017-12-08 @ 15:03
Found one of these in a drawer! Must've come with some old CRT. Now I can use my Performa on my LCD instead of a CRT taking up valuable desk space.
HP Elite 8300 CMT i7 3770, 16GB, GTX750, 2xSSD + HD, XP/7/macOS 10.13
User avatar
oeuvre
Postby bjwil1991 » 2017-12-08 @ 15:21
oeuvre wrote:Found one of these in a drawer! Must've come with some old CRT. Now I can use my Performa on my LCD instead of a CRT taking up valuable desk space.
Interesting part.
User avatar
bjwil1991
Postby LHN91 » 2017-12-08 @ 15:51
Interesting part.
It's required because Apple monitors communicate their capabilities in a specific way - so even if you have a DB-15 to VGA adapter, it won't necessarily work unless it properly communicates to the machine the desired screen resolution options.
LHN91
Postby Scali » 2017-12-08 @ 16:12
I finished my 2 Game Blaster/CMS clone cards:
https://youtu.be/kxWg1z-yBl0
Scali
Postby derSammler » 2017-12-08 @ 17:03
LHN91 wrote:It's required because Apple monitors communicate their capabilities in a specific way - so even if you have a DB-15 to VGA adapter, it won't necessarily work unless it properly communicates to the machine the desired screen resolution options.
Well, Apple used ID pins which are either connected or not by the monitor. Based on which ID pins are connected, the Mac knows which resolution the monitor supports. That's it. Those adapters will just fake 640x480, which almost always work. There are a few Macs however that can't output 640x480. On these, the adapter will not work.
Better adapters have a set of dip switches so you can also configure 800x600, 1024x768, etc.
derSammler
Postby Bancho » 2017-12-08 @ 20:25
Fitted my Panasonic CD Changer to my SS7 machine today. Hardware wise it is now complete. Just need to get down to Installing software and setting it up.
User avatar
Bancho
Postby Ozzuneoj » 2017-12-08 @ 21:28
Bancho wrote:Fitted my Panasonic CD Changer to my SS7 machine today. Hardware wise it is now complete. Just need to get down to Installing software and setting it up.
Wow, I had NO IDEA they made 5-disc changers for computers. I imagine that must have a lot of quirks under normal usage, like trying to get a game to read disk 3 specifically.
As for my retro activity today. I bought a pile of old graphics cards on Mercari the other day for $16 shipped because there were some decent entry-level PCI-E cards in the lot, along with a Voodoo 3 2000 PCI. I knew the V3 needed at least one cap replaced (they snap off easily), so I was ready to do some soldering when it arrived. I got the card, cleaned it up, plucked off two of the other caps on the edge that were falling off, replaced them with ones I had on hand from repairing a Voodoo 2 last year (3dfx\STB seem to use the same caps on a lot of cards), and the card is working beautifully. PCI V3 cards are getting harder to find, so I was quite pleased.
As a small bonus, the one AGP card in the lot I couldn't identify turned out to be a Diamond Stealth III S540 Extreme... which is an S3 Savage 4 Extreme 32MB AGP card. Should be a really nice card, and it does seem to work. :)
Time Machine = FIC PA-2013 2.1 - K6-2 500 - 256MB PC-100 - TNT2 Pro 16MB AGP - Labway Yamaha YMF719-E - Midiman MM401
Amibay For Sale Threads
I have lots of PC stuff for sale on Mercari! Get a $10 sign up credit with invite code VBGQMM.
User avatar
Ozzuneoj
Postby liqmat » 2017-12-08 @ 21:50
Looks great. Now you just need that Computer King case badge that probnot got with his case.
viewtopic.php?f=46&t=17341&p=609949&hilit=king+case+badge#p609944
User avatar
liqmat
Postby amadeus777999 » 2017-12-08 @ 22:29
Very nice case!
User avatar
amadeus777999
Postby Gered » 2017-12-08 @ 23:25
This is a really nice case! Any pics of the inside?
User avatar
Gered
Postby Anaxagoras » 2017-12-08 @ 23:51
Hi again.
Today I have started to do an inventory.
There are not much to count; a few boxes with cards from ISA, PCI, AGP graphics card, some controllers cards, IDE devices, CPU, RAM modules, cables, adapters...
I think that I can build a mutant PC. :-D
User avatar
Anaxagoras
Postby oeuvre » 2017-12-09 @ 15:00
whipped this up
User avatar
oeuvre
Postby clueless1 » 2017-12-09 @ 15:35
oeuvre wrote:whipped this up
No doubt populating those memory sockets made all the difference. ;)
User avatar
clueless1
Postby appiah4 » 2017-12-10 @ 04:37
Upgraded my P3 Slot 1 PC from a Lucky Star 6P2BX2 and Katmai 450 to an aBIT 6BE-II and Coppermine 700.
It was not as hasslefree as I would hope however as for whatever reason Win Me cant seem to initialize the PS2 port, MX300s SB Pro emulation driver cant find a free IRQ and its very picky about memory.
A reinatall od the OS is dur but I also have a Ga-BX2000 Rev 1.1 in the mail so maybe I should just wait and use that..
1989:A500|+512K|ACA500+|C1084S
1992:HIPPO-VL+|DX2-66|8M|GD5428|CT2290|S2
1995:PCI597-1|P133|32M|Trio64|V1|CT3980/2M
1998:S1573S|K6-2/400|64M|RagePro|V2/SLI|CT4500/32M
2001:GA-6OXT|PIII-1200|512M|GF3Ti200|MX300
2004:K8V-D|3700+|2G|X1950P|SB0350
User avatar
appiah4
PreviousNext
Who is online
Users browsing this forum: Baidu [Spider], kixs and 9 guests
