First post, by noobineer
I mainly want to play terminal velocity with s3d. I've never tried to source ram chips for a card before. I was hoping some of the experienced folks on here could double check the ones I found are correct. This card has existing chips marked with "VG264265BJ" and "751SA" and "-35". I believe this is Soj-40 EDO 35ns memory.
http://www.datasheets360.com/pdf/-8718897209892815320
I found some of this stuff for sale: ELITEMT M11B416256A-25J
http://pdf.datasheetcatalog.com/datasheets2/38/384008_1.pdf
It is more expensive to find chips that meet or exceed the 35ns at about $28 vs $8 for some 50ns. I wonder if I could maybe use 50ns stuff in the sockets as I read people saying the chips can usually work with something about 10ns faster. If 50ns is too slow for the current default clock speed, could I tweak the clocks after boot or flash the bios to permanently down clock the memory? The bios chip has "Stealth 3D 2000 Pro v3.04" written on it. I did find some FPM chips with good latency cheap too but I've read these wouldn't be compatible if it currently has EDO. Maybe I passed over something better and someone could link another option for me? Thanks.
Reply 1 of 2, by lazibayer
I think the mods don't like ebay links so I can only say I found a Taiwan seller who sells 5 pieces of the M11B416256A-25J chip for $6 + 4 shipped to the US.
Reply 2 of 2, by noobineer
I hadn't seen the listing with 5 pieces. Thanks!
