First post, by BSA Starfire
- Oldbie
Hi folks,
I have a Trident 9000B 512K graphics card in my 386 SX 33 system, but I can't seem to get it to work in 16-bit mode.
Here's a picture of my card and motherboard etc.
It seems to be match this card on statson.
http://stason.org/TULARC/pc/graphics-cards/U- … IDENT-9000.html
And is also very similar to this one.
http://stason.org/TULARC/pc/graphics-cards/U- … -TVGA-9000.html
Currently the jumpers are set like this jp7:closed jp8: closed jp9 a/b/c open. now this should give 16-bit bus operation as far as I can see. but take at look at the Dr Hardware result.
My Trident 8900B card gives these results when correctly jumpered to 16-bit bus operation.
Any ideas? I've tried the auto detect jumper(jp8) both enabled and disabled and it makes no difference. It's clearly running as an 8-bit bus card, here's the results from my Realtek RTG3105iEH, a card that is known to only run at an 8-bit bus speed for comparison.
And yes, I know Trident is a slow card and there are many better choices, but this is a nostalgia build of my first PC & that had a 512K trident. It's just bugging me that I can't get it set properly.
Best regards,
Chris
