-c cycles=500 -c oplmode=none -c tandy=on
DOSBox messes up and doesn't run the game. Any info would be great.
Thanks!
konc wrote:Try removing the oplmode command, it should work. It's not about having multiple commands, it's oplmode specifically.
Qbix wrote:well there is a limit to how many -c commands can be given.
Chilly Willy wrote:Is there no command line for window resolution?
Dominus wrote:It works better if you create configs for the games and use those configs with Dosbox.
