Reply 140 of 890, by Lifell
wrote:Sorry Lifell, I guess I just assumed you downloaded the game because your folder layout was different than mine, and so I went and found one online that was downloaded and it had those files you had so I just assumed. Sorry! I checked my readme and my version is 1.4, so maybe that is the difference? The registry thing was for that downloaded version, so don't worry about that. Although I will say, because of that I found a way to edit the registry and copy some files to the game folder from the disc so I can play without my cd mounted anymore. Hopefully Peixoto's work that he's doing on the 8 bit color mode helps your version - I just tried to look and I can't find anything about patching the game from 1.1 to 1.4. If you have color problems, before I used Peixoto's patch I used to use PalletteStealerSuspender and that helped the color problems I used to have. Good luck, Heart of Darkness is a great game - I still enjoy firing up sometimes!
No problem! To be honest I don't think it would be weird if people pirated this game. It's not purchaseable anywhere now as far as I know. I don't think old games should not be played just because it's not purchaseable anywhere. But that's my just my opinion.
Regardless, I think the version difference might be the problem then. I aimed for this patch because it fixes resolution and black bars stuff. The problem with colors is only an issue in Windows Vista/Windows 7 if I remember correctly. I'll look around for possible alternatives.
Either way, thanks for the help! Atleast I'm a bit closer now to the actual problem!
EDIT: It's probably a lost cause but I mailed Interplay regarding patching to the latest version. Although I said 1.4. I kind of assumed that's the latest version. Oh well...
