First post, by blackrax
blackrax
Offline
I can't seem to get MM3 working - it seg faults right after the NWC logo screen. According to the compatibility list it should work w/o any issues except the sound glitches.
Running the config/setup program (install.bat) crashes dosbox upon exiting - the same is, however, true for mm4-5 as well (although they work w/o any issues).
make.conf compile options:
CHOST="i686-pc-linux-gnu"
CFLAGS="-O2 -march=athlon-xp -fomit-frame-pointer"
CXXFLAGS="${CFLAGS}"
MAKEOPTS="-j2"
emerge options:
[ebuild R ] games-emulation/dosbox-0.63 +alsa -hardened +opengl 0 kB
Best Regards,
//b
