First post, by Almoststew1990
I went to have a look at a Facebook advert for a load of old PCs for £20, you know, a "help yourself to the old crap in our loft!" kind of advert! I came home with this:
Highlights of this lot for me are:
Can anyone tell me how to get into the case!? I don't want to break it!
The world's dirtest imitation IBM keyboard (at least it is mechanical sounding!)
This thing has a ever useful Slot 1 P3 500MHz, has a ZIP drive and has ISA slots...
This Motherboard has potential as it has ISA slots, and it turned out to be Slot A!
The two standard looking M-ATX cases had Pentium 4's GeForce MX's in them and were otherwise uninteresting...
The black, modern M-ATX case with a Pentium D is complete with the legendary, famous GT 210 😁
One big Dell has a Socket 370 P3 of some kind, the other is P4 which I haven't bothered opening yet.
I am also quite taken by the little Dell, which I've always loathed in the past (we used them at school and they were dreadfully slow), but I have a new appreciation of them what with this opening mechanism (and yes, I realise I am probably 10 years late to this party)
A couple of questions...
Would you recommend against just firing up the CRT monitors? They are very dirty and mouldy.
Can I clean the mould with standard mould remover or would even a tiny bit falling into the monitor be a big problem!
Reply 1 of 13, by martin939
Honestly? I'd throw the monitors in the garbage if they're mouldy. Really not worth the effort and the connections inside are probably rusty/corroded to hell anyway.
Also do check the power supplies in those PC's for leaky/bulging caps. That's the first thing I always check, don't want to have my room full of that awful electronics smoke 😒
Reply 2 of 13, by dionb
Nice haul, agree that the IBM is the hands-down winner, at least on looks & (nostalgic) value, although I loved those Siemens cases too.
As for mould - mould itself isn't a major problem, damp is. These things have been kept in a very humid environment. Once that is completely dried out you should be able to boot stuff up and see if works and/or is worth cleaning. As for cleaning, I'd be very careful with any chemicals around stuff like this. More likely than not cleaner would damage the screen coating (and I know IBM used some screens in the mid 1996 that were extremely vulnerable at the best of times), and it might impact the age-related yellowing. Nothing worse than a blotchy case.
I'd disassemble the monitor cases and consider washing 100% plastic parts in clean water or at most water with mild soap. Any other bits I'd rub with meths or something similar.
Reply 3 of 13, by Almoststew1990
Thanks for the tips. Maybe I won't bother with the monitors - I'll give them a go in a week or so and if they're no good they can go to the recycling centre along with a few empty cases.
The Pentium 3 Dell has a 1000MHz 133FSB chip which is a nice surprise. It is a SL52R. Is this particularly interesting?
Reply 4 of 13, by Tetrium
Are you sure about the ZIP drive being a ZIP drive?
The SL52R isn't anything remarkable, but it is a very useful CPU 😀
The Slot A board is very nice!
My retro rigs (old topic)
Report spammers here!
Reply 6 of 13, by Almoststew1990
Oh Ok... it has 8GB written on it, which sounds very very large for a zip drive actually! I have no idea what the tape streamer would be for - the guy was into music production I think, or would it be more for a back up?
The older Dell also has a 'zip drive':
Is the second 5.25" slot on the left Dell a zip do you reckon?
Reply 7 of 13, by Cyrix200+
Almoststew1990 wrote:
Oh Ok... it has 8GB written on it, which sounds very very large for a zip drive actually! I have no idea what the tape streamer […]
<snip>
That's a tapestreamer, you can Google 'Dell Travan' to see more pictures.
1982 to 2001
Reply 9 of 13, by yawetaG
A tape streamer is usually used for back-up to tape, for long-term storage of large amounts of data (e.g. professional audio files, but also and more often system backups). There are different types of tapes (for different types of tape drive), and they can get pretty expensive...
Reply 10 of 13, by Almoststew1990
I've washed out the nice case and now it's ready to get the motherboard back in. I was a bit confused when the whole pack panel rotated out but now I really like the design!
On the plus side, when I was cleaning the Socket 370 motherboard, it turns out it has a 1133MHz P3-S SL5LV which I've never had before. On the other hand, the caps look like this:
The board is a Gigabyte GA-6VTXE with a VIA 694T chipset, AGP and ISA slots. Should I just give it a go as it is? is it worth saving (not that I've ever replaced caps before)
Reply 11 of 13, by kixs
https://i.imgur.com/PaiGPxCh.jpg Can anyone tell me how to get into the case!? I don't want to break it! […]
Type 1:
Unlock the keylock at the back and lift the holders on the top of the case and push forward and up.
Type 2:
At the back you have a keylock and above it is one screw. First check the keylock is unlocked then unscrew the screw. Then you just push the upper side to the front for a few centimeters and lift it.
Reply 12 of 13, by ODwilly
https://i.imgur.com/xpU5iCXh.jpg […]
Caps look pretty borked, highly desirable, checks off everything for a perfect fast 98 pc, isa, Tualiton support, agp. Keep it and recap it for sure! Or sell it off as-is to someone with the skills to do so 😀
Reply 13 of 13, by Tetrium
I've washed out the nice case and now it's ready to get the motherboard back in. I was a bit confused when the whole pack panel […]
Cases with the quarterly rotated PSU were more tailored for Slot-based boards. Using a board with a socketed CPU (which is basically >95% of all boards, so to say) will present poor air clow as the PSU will probably try to suck air in the opposite direction as the CPU HSF.
The GA board looks like a keeper, even despite the busted caps 😀
