bosito7 wrote on 2024-05-20, 07:10:Hello. Sorry for writing in an old post.
I got a card with the same chip.
I am not able to find the DOS or Windows drivers.
Co […]
Could you please share the ones you used?
Many thanks in advance
Well, I have found the Drivers. I am attaching them if someone needs them I can save some troubleshooting.
I confirm they work well on Win 95/98. Win95 will through some errors but will work.
In both win95 and 98, I did install using the system update driver option and not the drivers installer perse.
I did not test the Original DOS Driver since UNISOUND v0.81b worked after some troubleshooting. Long history short don't use SET with the recommended config for UNISOUND, just run UNISOUND.COM in your AUTOEXE.BAT. You can check my original post with the issues I had here Re: UNISOUND - Universal ISA PnP Sound Card Driver for DOS v0.81b
BTW, according to my research, it seems CMI8329a and CMI8330 are very close and 8330 drivers might work in Windows. This remains to be tested. If I do the tests I will come back with the results.
