Best 386 Motherboard?
Re: Best 386 Motherboard?
Postby BSA Starfire » 2018-2-03 @ 14:12
Yep, my IBM PS/1 model 2133 386 SX 25 uses 72pin FPM modules along with the 2MB on the motherboard itself.
386SX 33MHz,4MB Ram,ALi M1217 motherboard,OAK OTI077 1MB. Seagate ST1144A.
386DX 25MHz,IIT 387,8MB RAM,Opti,32K cache,WDC90C30 512K.Conner CF170A.
IDT Winchip C6 200MHz,DFi P5BTX/L,Number Nine S3 ViRGE 2MB,SoundBlasterCT2260,1.2Gb Fujitsu.
User avatar
BSA Starfire
Postby feipoa » 2018-2-03 @ 22:27
You guys with all your weird hardware combinations. I hope nobody come's forth with 30-pin EDO SIMMs.
User avatar
feipoa
Postby Jupiter-18 » 2018-2-03 @ 23:03
That'll be the day eh? :D
I really have appreciated all the help, it's been a great learning experience!
How about EISA? It's kind of the PCI-X of the 386/486 era, correct? Mostly server usage?
Jupiter-18
Postby Anonymous Coward » 2018-2-04 @ 00:51
EISA for 386s exists, but it's mostly an OEM thing (nonstandard motherboards that only fit in the manufacturer's chassis). These boards tend to be a bit dated, but could still be fun to play with. Compaq, ALR or AST probably made the better ones, but AST had weird 64-pin memory. There are a few AT formfactor EISA 386 boards out there, but you can count them on one hand. I've never seen one in person or for sale online.
Will the highways on the internets become more few?
User avatar
Anonymous Coward
Postby Jupiter-18 » 2018-2-04 @ 05:32
Is EISA worth it to look for in a 386 system?
Jupiter-18
Postby 386_junkie » 2018-2-04 @ 09:36
Jupiter-18 wrote:Is EISA worth it to look for in a 386 system?
https://en.wikipedia.org/wiki/Extended_ ... chitecture
It would be worth your while to investigate the technology and have a better understanding of it first.
As with everything, there are limitations. To be "worth it", it largely depends on what you hope to achieve.
User avatar
386_junkie
Postby Anonymous Coward » 2018-2-04 @ 13:04
It might be worth it for a hard disk controller or a network card. I highly doubt that the 386 can take advantage of the extra bandwidth of the EISA bus, but if you have a lot of RAM installed, it might be advantageous to have your adapters on a bus that has more than 24-bit address lines. I've never used a 386 with EISA bus, but it's something on my list of things to try.
User avatar
Anonymous Coward
Postby Jupiter-18 » 2018-2-04 @ 22:06
OK.
I'll put that lower on my list.
EISA vs VLB?
Jupiter-18
Postby feipoa » 2018-2-04 @ 22:19
EISA for 486 would be fairly high-end and a rarity today. The motherboard and EISA cards might be costly and difficult to source. If you aren't familiar with EISA, then you'll need to do some learning - they use different configuration files for each EISA card, which I think gets loaded into the NVRAM of the RTC module. I've never used an EISA system. Too fancy for me, but if I had one, I'd use it.
VLB for 486 was very common and is a very popular setup. The motherboard shouldn't be too difficult to source unless you want a PS/2 mouse header. High-end VLB graphics and SCSI controllers are getting expensive and more difficult to acquire.
User avatar
feipoa
Postby 386_junkie » 2018-2-04 @ 23:50
Your thread has got quite subjective... it seems to go in different directions every time I go and comeback... and being 386 related, I like it!
In answer to the thread title though, "the best 386 motherboard"... you have touched on one of my flagship projects. I believe the answer to this would be from the below eight: -
Image Image Image Image Image Image Image Image
All are 386, and all are VLB. I have tested each to varying degrees, though the project is still very much work in progress. Two things have happened which has slowed things down a little, they are: -
1) Starting a new family (time is now a scare commodity these days)
2) The test hard drive I used went on the blink, along with many of my test results
I will be picking this back up when I get the chance... once the ship has steadied and I sort a new hard drive from the stack.
Regarding EISA, I have done a fair bit of testing on this as well and have made a few threads here on Vogons... some are below in my signature along the bottom of this post, and another is of the various EISA graphics cards that are out there: -
viewtopic.php?f=63&t=50370
There is lots of information and resource to look through/at. It is a fun ride... personally I would recommend you do both a 386 VLB and 386 EISA system, testing them both for yourself and for Vogons, by publishing the results of each online... possibly even comparing them. No better way to learn and support Vogons.
User avatar
386_junkie
Postby The Serpent Rider » 2018-2-05 @ 00:12
They should be classified as 486 boards though.
User avatar
The Serpent Rider
Postby feipoa » 2018-2-05 @ 03:10
Those all look like motherboards with a 386/486 hybrid chipset. Even the board with the ALi M1429 is a hybrid chipset, although it does not contain a socket for a 486. I recall seeing this chipset with a 486 socket as well. To me, the ALi M1429 looks the most interesting because it lacks the 486 socket and can pretend to be a true 386. It would be nice to see some benchmarks taken with the ALi M1429 with DX-40, DLC-40, SXL-40, SXL2-50, SXL2-66, SXL2-80, DRx2-50, DRx2-66, BL3-50/66/75/80/100/110, RapidCAD, and Transcomputer. Basically, all these, viewtopic.php?f=46&t=53096 . From what I recall from another poster, a 386 board with VLB only seems to show any benefit from VLB when using clock doubled CPUs. I'll be working on a mega 386 benchmark thread in the far future, run on 386-native motherboards. It might be of value if I can cross-reference such a benchmark thread to a 386 board with a VLB slot to see what percent improvement there is with the VLB based on various CPU speeds.
I recall running a Cyrix 5x86-133/4x with an ISA ET4000AX and a PCI Trio64 in DOS Quake. If I recall right, the Trio64 scored around 17.7 fps, while the ET4000AX scored around 14 fps. I thought the gap would be larger, but I guess this game is really held cripple by the CPU for this configuration. I wouldn't be too surprised if the ISA vs. VLB for 386 had a similar performance ratio.
User avatar
feipoa
Postby kixs » 2018-2-05 @ 07:41
Junkie_386:
nice collection of boards :) I have 4 or 5 hybrid boards...
feipoa:
I have a similar project planed for years now :lol:
I tested one of my Opti hybird boards with DLC-40 a few years ago and it gains a few fps with vlb card in 3Dbench. Quake is specific as it needs a fast FPU. I'm sure it wasn't any difference there or maybe just minimal.
My Amibay: SALE | BUY - Updated on 2018-07-17
User avatar
kixs
Postby Anonymous Coward » 2018-2-05 @ 09:35
feipoa wrote: From what I recall from another poster, a 386 board with VLB only seems to show any benefit from VLB when using clock doubled CPUs.
In my opinion, it has more to do with whether or not the CPU has any cache. When I compared a VLB mach64 with an ISA mach64 on an OPTI495SX motherboard, the i386-33 (overclocked to 40) only showed a small performance increase using the VLB card. However, the TI486SXL-40 and BL3-66/100 both benefited greatly from VLB.
The SXL-40 was not clock doubled, so I can only assume it must have been the cache that made the difference. Too bad I didn't have a 1kb DLC chip to compare.
User avatar
Anonymous Coward
Postby 386_junkie » 2018-2-05 @ 13:59
feipoa,
Do you have the link of the other poster? I disagree should anyone say that there is no benefit shown by having VLB on a 386 board. Even with a DX40, on numerous occasions I have managed to squeeze out a couple of extra frames. Now ok, on the grand scale of things this might not seem like much... but for a standard 386-DX40, when you are only getting around 10-15 fps anyways... that can be increase of around 10 to 20 percent! Now consider upgrade CPU's...
You are both right regards to clock-doubling and cache ... though the performance of the above boards was much more sensitive to the presence of cache than an increment of FSB. RAM with a lower latency also played a part, and is why I set about fabbing some 40ns SIMMs.
User avatar
386_junkie
Postby feipoa » 2018-2-05 @ 23:54
Starts somewhere around here: viewtopic.php?p=468628#p468628 on page 8 and reaches an apex around page 10. The user with the results is skv400. You did comment shortly thereafter in this thread. Probably too long to skim.
User avatar
feipoa
Postby Jupiter-18 » 2018-2-06 @ 00:00
i absolutely plan on multiple 386 builds
a hybrid vlb is one
another would be eisa
a third would be pure 386 isa only
Any particular tips for that? Pure 386, no hybrid chipsets, isa only?
Jupiter-18
Postby feipoa » 2018-2-06 @ 00:10
My preference is a pure 386. If you want a VLB, I like to use a more powerful VLB 486 motherboard from ASUS with PS/2 mouse support. If you want EISA, I think EISA 486 is more conventional. But if you want to go all out, the go pure 386, hybrid 386 w/VLB, 5x86 VLB, 386 EISA, 486 EISA. If you were just building one system and like 386's, my preference is pure 386 motherboard with a faster PGA132 upgrade CPU.
User avatar
feipoa
Postby gdjacobs » 2018-2-06 @ 03:42
I'm actually looking at ways of having a slower 386 CPU.
User avatar
gdjacobs
Postby jesolo » 2018-2-06 @ 19:16
386_junkie wrote:All are 386, and all are VLB. I have tested each to varying degrees, though the project is still very much work in progress.
Nice collection - I have two myself (one unfortunately not working and I'm still trying to fix that one).
I noticed the one motherboard you have has an OPTI 495SLC chipset - I have the exact same motherboard (I believe it's actually a DataExpert EXP3406) but, mine has an OPTI495XLC chipset.
Have you also found with this motherboard, in protected mode (i.e., with EMM386.EXE loaded), that the turbo function does not work?
User avatar
jesolo
PreviousNext
Who is online
Users browsing this forum: .legaCy, Bige4u, bjwil1991, blurks, brostenen, Cyrix200+, Eleanor1967 and 16 guests
