First post, by keenerb
Physically, it's in pretty good shape. Floppy doesn't work, but I understand that's pretty common with these, and I've ordered a replacement belt.
My biggest problem is that the battery is no good. It's a sealed lead acid 6v 1.8ah battery, and I can't identify any appropriate replacement anywhere.
Also, has anyone managed a Gotek installation into one of these? It looks like the floppy connector is proprietary but carries standard floppy signals. I'm considering hiding the gotek inside the system and routing a USB extender cable and switches out through the expansion plate cover at the rear of the machine. Looks like there's plenty of room inside.
Should I be worried about that yellow rechargeable battery?
Reply 1 of 1, by Unknown_K
The floppy drive is 720k (belts break due to age), battery is sealed lead acid I think (never looked into replacing it but I might).
