First post, by Doppler
Hi!
Can anyone identify this chip? I try to programm it with external USB flasher but can't find any refrence for it in the flash software. Non of these numbers fit to the predefined chip profiles.
The chip is DIP28 pulled straight out of the S3 Virge/GX2 AGP SG200A graphics card.
Heres the photo:
Reply 8 of 8, by lazibayer
Doppler wrote:
Is it possible to directly replace this ROM with flashable memory? In other words: if I buy and flash a Winbond memory with the S3 BIOS and swap these chips, then will it work?
Highly likely it would work.
