First post, by Wolven
Hello, all. I'm Wolven and I've been into computers since the 80ies, starting off with the C=64. I've been building my own PCs since the mid 90ies and it is one of my favorite things to do.
In this post I'd like to show off my retro Windows XP build. It features most of the parts from an old PC I had back in the early 2000s. I'd forgotten about this PC, (I've had so many through the years) which I'd given to my ex some years ago. It's been collection dust in her basement for a while, until I found it again recently and decided to restore it to its former glory.
I was planning to dual boot this with Windows XP and 98SE off two hard drives, but after spending a few days trying and failing to get sound working in DOS mode, (VIA KT600...) I opted to just go with XP. I have another Win98 build planned, but I don't have all the parts for that yet.
So without further ado, here are the pictures of the hardware and the final build.
  • Motherboard: ASUS A7V600
    CPU: AMD Athlon XP 2400+
    RAM: 2x 512MB Corsair XMS DDR 333Mhz
    HDD: Samsung 320GB S-ATA
    GPU: MSI Geforce4 4200 Ti
    Sound: Sound Blaster Audigy
    Case: Lian Li PC60
Finished Build
Case Front
Case Side
Inside
Ghetto mounted 120mm case fan (The dual 80mm was so noisy...)
RAM
HDD
GPU
Sound card
Optical drive
Fan controller
The fan controller is not connected, as it makes an annoying high pitched whine when the fan speeds are turned down. I just left it in there since I'm missing two of the bay slot covers for the case.
If anyone knows how to fix the sound from the fan control, I'd be very grateful. I'm not sure if it made that sound when it was new...
So, that's my first retro build. Not as cool and beige as some of the other builds I've seen here, but it was a fun project. 😀
Reply 1 of 3, by Private_Ops
Very era fitting machine. Nice.
Reply 2 of 3, by Wolven
Thanks. I'm glad you like it.
It is mostly original from how I built it, back when it was new. I remember paying a small fortune for the case. Aluminium and Lian Li was all the rage back then. It's missing some blue cold cathode lights though. I might pimp it out with some LED lights later on. 😎
When I found it again it had a Geforce3 Ti200 installed, which I replaced because it has a very noisy cooler and I wanted a little more oomph. Also the optical drive is a new addition. It was fitted with a IDE DVD writer, which I'll be using in my upcoming Win98 build instead. And I remember it having two of those hard drives, which I ran in Raid 0, but I think one of them died.
In the future I'm hoping to come across some original bay covers, or some other brushed aluminium goodies, so I can remove the black fan controller and optical drive. I know you can buy the covers, but those I've found are half way across the world, so the cost of shipping is 4x the price of the covers...
Reply 3 of 3, by Private_Ops
I really wish Lian Li had kept up with the times in terms of case design. They still had some decent ones. I've got 3. I love them. Two of them are the older "Lancool" series K7s. Built like freakin tanks (steel chassis).
