Increase window size
First post, by Paolo_R
I'm running DOSBox on a Windows7 laptop. The DOSBox window takes up about 1/3 of the screen. Is there anyway I can increase the DOSBox window to fill the W7 screen? I'm not interested in increasing screen resolution - just the physical size of the DOSBox window (with the fonts looking larger as a result.)
I've tried the various combinations shown in the .conf file but the DOSBox windows stays stubbornly at its 1/3 size.
Thanks
Paul
Reply 2 of 9, by Paolo_R
I'm afraid this has no effect. I've tried fullscreen and also full resolution, window resolution. I've also tried scaler=normalx2 and scaled.
Reply 3 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
did you read the comments at the top of the options file ? (with regards to the output option ?)
Maybe changing that will help you out
Water flows down the stream
Reply 4 of 9, by RobertJ
This is how I got a larger window:
fullscreen=false
fulldouble=false
fullresolution=1920x1200
windowresolution=1024x768
output=ddraw
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper-0.74.map
usescancodes=true
8-bit Collection: 4 64Cs, 6 1541-IIs, 1 C128, 2 1571s, 1 C128DCR
Vintage DOS: Dell Optiplex G1, ATI Rage IIC, Sound Blaster CT4520, Thrustmaster FCS Mark II, Gravis PC GamePad
Monitor: Dell 20" 2007FPb
Reply 5 of 9, by Paolo_R
Yes,I certainly did.
Reply 6 of 9, by Paolo_R
Thanks.
RobertJ wrote:
This is how I got a larger window: […]
fullscreen=false
fulldouble=false
output=ddraw
autolock=true
sensitivity=100
waitonerror=true
usescancodes=true
Is mapper-0.74.map your own mapper file? I don't appear to have a mapper.txt file (which appears to be the default.) Anyway, apart from the mapperfile entry, there is no change to the window size.
Paul
Reply 7 of 9, by konc
Just a stupid idea, but are you sure you're editing the correct .conf file? Add something dummy in the [auotoexec] block for example to make sure it's the one used
Reply 8 of 9, by Paolo_R
Konc
I've only got one .conf file on my PC in my c:\users\paul\appdata\local\dosbox folder.
Reply 9 of 9, by Paolo_R
I've realised I have made an error - assuming that anything after # was a comment I had stuff like
windowresolution=1024x768 #600x400
so DOSBox was not accepting the window resolution parameter as a valid entry. It's fixed now - thanks to all who offered solutions.
