leileilol wrote:Only in a handful of Direct3D games daring to go without any Z it would allow that. Battlezone is the only one that comes to mind and it's ugly on a single V2 at that high.
Oh, that's too bad. It seems kind of unnecessary that they would prohibit you from raising the resolution. If it doesn't work, it doesn't work. No harm no foul. Instead they had to cap it so even in games running 50 FPS, you can't ever enjoy the game at a higher quality level.
I came across these Fast Voodoo2 drivers, which I take it is an open source fan project but it appears to be very brand specific so I'm not even sure it would benefit me (mine is a Magic3D card). Since the CPU stops being a bottleneck at roughly 400 MHz and I just so happen to have a 400MHz board laying around, I thought it would be the perfect combo but alas, I don't have SLI and many of the games that look their best on Glide would look that much better at 1024x768. I guess I can't even SLI properly unless I get an identical branded board. I keep forgetting what year we live in, as crossfire at least doesn't care about this as long as the chipset is the same.
